2200 lbs - Is it possible?
If I read the SCCA rules for F prepared correctly, a 944 na can run at 2200 lbs. I weighed my car the other day, and it came in at 2840 lbs. Is it possible to get 640 lbs out of the car? I hope to be able to still drive to events (no trailer). Don't know if I can get that much weight out, but it sounds like fun. Any suggestions would be appreciated.
Old 09-10-2003, 08:11 PM
ae1969's Avatar
Send a message via ICQ to ae1969
2200 lbs.............. good luck.
It may be close. I think I have seen about 2400 hundred for some of the racers..... but those had roll cages and other safety gear in them.
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 09-10-2003, 08:16 PM
scheistermeiste's Avatar
Send a message via AIM to scheistermeiste Send a message via Yahoo to scheistermeiste
Carbon fiber body pieces, or fiberglass, expensive but saves a lot o weight
Special Edition 924S 1988 <- SOLD!
Asking if you should replace that timing belt is like asking if you should re-use a condom that may have in hole in it with a hooker.
Old 09-10-2003, 11:24 PM
Blackfoot's Avatar
even with fiberglass panels (carbon fiber, you need to be bill gate's son for that), think you'll have to gut the car out to even be close to 2200.
will fiberglass, lexan windows, no dash, carpet, insulation, one racing seat even do it? dunno.
Old 09-10-2003, 11:59 PM
dont forget no paint! paint weighs a lot!
Old 09-11-2003, 01:07 AM
Dave951M's Avatar
Yes, it is possible. Change out the seats, strip out the interior, remove undercoating and interior insulation, change rear torsion carrier to an aluminum unit like Koklen, aluminum torque tube, cf fenders and doors, lexan hatch, lighter wheels (Fiske or similar), lexan for window glass, remove window regulators, ditch a/c and p/s.
Dave951M
86 951 Blitzwagen
82 931 Basket Case (for now)
Old 09-11-2003, 12:37 PM
Roger Hall's Avatar
That would be a beast to drive to the track.
Roger Hall
81 924 N/A
Some people are like Slinkies. Not really good for anything, but you
still can't help but smile when you see one tumble down the stairs.
Old 09-11-2003, 05:30 PM
