Post Outside door handle
hey Pelican lists that the pre 85 outer handles are 71.00 and the 85.5 (which is my car) are 197.00 what is the difference in them. Is it just power doors or something, cause mine arent power anyways, will they fit or do i have to pay 200 bucks per door to fix cause both the doors dont open from the outside, only the inside.
Old 05-14-2001, 10:04 PM
Post
You might be able to adjust the linkage in the door handles. I had the same problem when it was cold this winder. Unfortunatly i didnt want to talk the window guide off so i just waited till it warmed up again.
But it might save ya some bucks
If you drive it, Race it
Dave
'87 944
Old 05-15-2001, 03:05 AM
Post
so how do you get in???? does someone have to stay in the car 24/7 to open the door from the inside for you??? lol.
Old 05-15-2001, 05:36 AM
Send a message via Yahoo to Cebu
Post
It is not necessary to replace the door handle to fix the problem of the door not opening from the outside. Remove inner door panels. Squeeze the outside trigger and observe inside linkage movenent. Disconnect and lengthen rod to adjiust, reconnect and test outside door handle trigger.
Old 05-15-2001, 05:59 AM
Scott R's Avatar
Post
You might have a set of broken connecting clips. You will see a metal rod coming from the outer handle to the latch, at the end is the adjustable clip that attches the rod to the clip. Both of my clips eventually cracked from age and lack of lubrication at the latch. Porsche sells that rod and clip seperate from the door handle for around $15
Old 05-15-2001, 06:39 AM
Post
Thanks alot Scott. It is the plastic clip, but i wasnt sure that they sold them seperate. No someone doesnt stay in it 24/7. the driverside dorr works if you pull up and out really hard. the other only works from the inside. Hey SCOTT do you have a link to get 'em.
Old 05-15-2001, 09:41 AM
Scott R's Avatar
Post
I just went to my local Porsche dealer. Here in Denver.
Old 05-15-2001, 09:53 AM
Post
my passenger side handle won't squueze , well it's really hard to sqeeze to open it. Any thoughts on that?
Old 05-15-2001, 10:21 AM
justin's Avatar
Post
Hey Donnie...mine does sorta the same thing,my driver side door is real hard to open,and my pass. one is hard to squeeze when it's cold out.(I hear it from my girlfreind everytime)but,I ordered a used one about 3 months ago from partsheaven.com ,just havn't put it on yet. I need to get it keyed to fit my key.(driver side).
Drive it like you stole it........Justin
Old 05-16-2001, 07:57 AM
Scott R's Avatar
Post
You don't get the door for your girlfriend?
Old 05-16-2001, 11:49 AM
