ruechaos's Avatar
What happens if I disconnect the idle positioner?
Hey guys! The car is running pretty good, mostly thanks to all the great help I've recieved on this board! Just a few little things to get it all "just right".
One of the little things being the idle. At start it's right around 900, and once it gets warm, around 1k to 1.1k. Is that normal?
I was thinking that maybe it has something to do with the idle positioner, so just to see what would happen, I disconnected it. Once while the car was cold, and once while the car was warm. It made no difference in the idle, when I dosconnected it, no one bit. Now is that normal?
Thanks a lot for all the help you guys have been. All I need is a lower valence, and she'll be good to go!
-Tony
'84NA Engine, '87NA Brain/AFM/wiring
harness, all in an '87S Body....AND IT
RUNS!!! kinda...
Old 09-05-2003, 05:56 AM
You need to disable the idles stabilizer and then set the mechanical idle.
To do this you connect a dwell/tach to the primary (green) wire at the ignition coil, start the engine, let it warm up, and then put a jumper wire between pins B and C of the diagnostic plug on the driver side fender.
Now you can adjust the idle by-pass on the throttle body to set the idle to 840 +- 50 RPM. Remove the jumper, and you're done.
Cliff Hipsher
'87 944 India Red
'86 951 Kalahari Metallic
Old 09-05-2003, 07:21 AM
ruechaos's Avatar
Sweet. Thank you kindly!
-Tony
RUNS!!! kinda...
Old 09-05-2003, 07:32 AM
SoCal Driver's Avatar
Think Wilks has the process on his web site. Used to as one methode of getting rid of the return to idle stumble that the early 944's experiance. Keep us posted on how it works for you.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 09-05-2003, 11:21 AM
afx afx is offline
afx's Avatar
Send a message via ICQ to afx
What is a dwell/tach and where do I get one?
85.5 Red 944
Http://members.rennlist.com/afx
Old 09-05-2003, 12:55 PM
Good car parts store or Snap-On or Sears or Mac Tools.
Old 09-05-2003, 12:58 PM
A "Dwell/Tach" is a multi-function tester. You can test engine RPM for 4,6, & 8 cylinder engines, voltage, and ignition point Dwell.
Dwell refers to the relationship between how long igintion points are open and how long they are closed. The units are dgrees.
Any good parts store like Pep Boys, AutoZone, Advance Autop, etc. should have them.
Cliff Hipsher
'87 944 India Red
Old 09-05-2003, 02:07 PM
afx afx is offline
afx's Avatar
So what does the Dwell/Tach do while you are trying to adjust the idle? Does it just allow you to see what RPM you are at? If that is it, would you not be able to just look at the tach?
85.5 Red 944
Old 09-08-2003, 11:20 PM
Would take a very long screwdriver or some creative mirror placement.
Then you could run back and forth between the drivers seat and the engine compartment.
Old 09-08-2003, 11:39 PM
meister member
speedracing944's Avatar
Isn't it also more sensitive? (Dwell Tach)
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 09-08-2003, 11:41 PM
afx afx is offline
afx's Avatar
I was just thinking I could get my dad to watch the RPM while I adjusted. Would that be good enough? I would rather do that then pay like 30 dollars for the gauge. But if it is needed I will go out and buy one tomorrow.
85.5 Red 944
Old 09-08-2003, 11:57 PM
I've found your problem!!!!
Here:
RUNS!!! kinda...
Do hope you also installed the test plug for the 87 hardware. You have to jump between pins B and C then adjust the idle. Other wise the DME keeps trying to adjust the idle.
Also installed the idle possistioner from the 87 including all of the vacuum valves and such.
Check the DME temp sender too.
Of course your temp gauge sender for the 84 block is a single pole unit while the 944S temp gauge AND warning light require the two pole sender that penetrates the water jacket.
Old 09-09-2003, 09:06 AM
