nige944's Avatar
Little things that made me love my car again.
Just thought I'd share what little things I did recently to make my car infinitely more enjoyable.
When I got my car it was ok, but now it runs very smoothly and mostly rattle free, apart from the drivetrain issue I posted about earlier and few other minor issues.
Removed nut + bolt from middle of the bottom of the radiator whose sole purpose was to rattle.($0)
Replaced 02 sensor and upgraded to a 3-wire (pretty easy as all wiring was there) helped pass emissions. ($40 ford one from autozone)
Replaced AFM - biggest difference as old one was wearing out and had been f***ed about with a lot, new one has not been altered. - helped pass emissions. ($20 from wrecked 56k miler via ebay)
General Tune up - plugs(bosh-4 $4ish each), distributor cap and rotor (cheapo wells from autozone $50) - also an amazing difference.
Adjusted Throttle cable and found the throttle stop bolt that had fallen out and was lying in the gunk. ($0) Another big difference...
I'm planning replacement seat covers, FR Wilks Chip is on the way (I hope :-)), have to fix the clunking from the inside of the doors when I corner, replace the rear curtain, replace that warped rear disk, new exhaust... etc...
What small things have you done/ are planning to improve how you feel about your car?
89 944 Turbo 115k miles, Stock
96 Range Rover 4.0 SE 130k miles.
84 944 170k miles, FR Wilk Chip, Sold.
"Don't listen to me, I dont know what i'm talking about"
Old 09-10-2003, 11:37 AM
SoCal Driver's Avatar
I'm going to jack up my radiator cap and put a 951 under it.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 09-10-2003, 12:06 PM
Non Compos Mentis
I felt much better about my car after the roll cage and Hoosiers.
Old 09-10-2003, 12:28 PM
nige944's Avatar
You'll have to write some instructions on that one...
Old 09-10-2003, 02:02 PM
todwic's Avatar
Send a message via AIM to todwic Send a message via Yahoo to todwic
dude, yer gonna love that chip If you have a sketchy idle, it will smooth right out
*Disclaimer: The person above is actually dumber than he appears.
my web site Torque values maintainance and repairs lots of my rebuild pics weights and measurements
'84 944 auto/ps/ac/cc
'86 951
Providing ignorance one post at a time.
Old 09-10-2003, 08:24 PM
tomeiche's Avatar
little extras
how about these.cost not a lot but looks and feels alot.1. L.E.D brake light fitted to top of hatch 2.L.E.D red bolt thrus on rear number plate wired to brakes 3.Max power red flat strip lights under dash each side .When door opens footwell lights red .Goes with mat colour.4 .Blue / white oval fogs fitted in front spoiler.(seperate switch with relay).4.Rage oval exhaust tip with blue L.E.D.light ring remote control 5.AStrali wooden wheel with brass rivets round.(better grip and i can now see temp guage) 6. Refaced clocks with red dial kit .7.use synthetic oil and add Roil Gold metal conditioner.Do web search to find details 8. Give engine a good 12000 mile petrol treatment(gas?) enuff said
Old 09-10-2003, 09:06 PM
ldl ldl is offline
ldl's Avatar
tomeiche....
Do you have any pictures of these mods?
If so, i'd love to see how it all comes together.
85.0 944 Automatic
^ Bending my wallet over at every possible moment.
Old 09-10-2003, 11:42 PM
I am afraid I am a purist and like to keep my car as it came out. Apart from services, belt changes and repairs on clutch slave cylinder, temp switch, speed/position sensors, new door handle, replacement fuel pump and relay and the inevitable tyres and exhaust, that is it. I was lucky though,previous owner had motor completely overhauled by agents at 106K km after an oil pipe came off, and the car has 140k on now. Only thing I may like to do is change the cookie cutter wheels or do them up.
Had a 44 Harley 10/12 which I reconditioned and it used to upset me when I saw an older classic model chopped or customised, and I feel the same about my 944. They don't make them any more so cannot be replaced.Different strokes for different blokes, but the people in my Classic bike club,MG clubs,vintage and veteran car clubs etc are similar minded.
Old 09-11-2003, 12:49 AM
flangermog's Avatar
Everybody say "Uncle Ben's"....
(x)'89 944 S2 Cabriolet (Guards Orange) :
( )'90 944 S2 (Maraschino Dead!) :
( )'89 Audi 90 Quattro 2.3 20V :
( )'92 Renault Clio 1.4 :
Old 09-11-2003, 04:14 AM
tomeiche's Avatar
hi IdI will take pics this week. then will take scanner out of box its been in for year and will ask 12 year old son what to do.should be good.
944 guards red 82- slotted rear turbo spoiler- new dash cover- red dials - k@n dropin filter- throttle cam upgrade- astrali wood steering wheel {can now see temp guage}-(www.astrali.co.uk)blue/white fogs {RING}-reversing sensors-alpine cd-roil gold engine protection
Old 09-11-2003, 04:49 PM
vott does ziss do?
ronin's Avatar
best conversion you can make hands-down. and guess what? it works on any car!!
Old 09-11-2003, 06:09 PM
nige944's Avatar
Funny :-)
Old 09-11-2003, 07:12 PM
TCMdocs944's Avatar
Biggest inexpensive change has been replacing the little rubber bits that fail with age.
Master cylinder reservior grommets - $5 now no leaks
Door handle and Mirror seals - $10 now no black "drip" marks between washings.
Hood badge rubber mount - $6 plus "testors" painted the badge...Nice
Rubberized sealant around bottom of windscreen - $5 now no air sound in cabin
Made all interior lights work - $15 bulbs etc..clean terminals..pain in the ass
R&R rusted license plate bolts front and back - $2
Misc. engine plugs r&r made of plastic or rubber - $30
Sometimes its the little things that mean alot.
BTW- if one more plastic piece in the engine compartment falls apart in my hands, (making me drop my wrench and knock over my beer) I am going to rip out my whole dme harness! Time and heat love plastic and rubber.
83 944 white w/Boxster wheels
Planned mods- custom leather interior, 968 antenna, soundsystem, 968 style rockers, clear sidemarkers
Old 09-12-2003, 11:10 AM
ldl ldl is offline
ldl's Avatar
Hahaha, all right. No rush, no rush. And im sure it wont be much trouble to scan them, but if it turns out to be taking more time then's needed... Just forget about it. No stress.
Ok all, Stay safe.
Bye.
85.0 944 Automatic
Old 09-12-2003, 05:47 PM
