-   -   Frame Damage -Can this be fixed (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/12905-frame-damage-can-fixed.html)
SplitKane 06-07-2001 07:26 AM
I don't know how much frame damage can be fixed!
Recently I rolled my 944 into a tree at about 5-10MPH. It pushed the bumper in and crunched in the part of the frame that the bumper shock is mounted on. This frame piece is now squashing the oil filter a bit.
The steel member is kinked back on itself!
Can this be straightened?
http://www.pelicanparts.com/ultimate...ads/Damage.jpg
Scott R 06-07-2001 07:54 AM
Yes, but when you are that close to the strut tower the will most likely have to cut and weld. When you bend metal it streches and weakens. That area will forever be a weak spot. Certinally not a great idea if this is a track car. But when I worked in a body shop I saw plenty of cars that looked worse then that, and they came out fine. These days they use laser alignment equipment coupled to the frame straightner to get it correct.
SplitKane 06-07-2001 01:12 PM
Scott,
Thanks for the info
I saw a frame straightener today and he said this would be no problem. He showed me some things he is working on and you are right. some things are a lot worse.
Thanks for the input!
SplitKane 06-08-2001 07:53 AM
Scott,
In regards to your comment about strength, This kink is forward of the strut and I believe the only weight it is bearing is the bumper (which I plan to convert to a 951 style)
If it was repaired as you say by cutting and welding, is that something which would require removal of the engine - to get in there? You can see where it is!
Scott R 06-08-2001 08:09 AM
Not that I have ever seen. In most cases they just pull the fender and attack it from the back side. Or move whatver they need out of the way. You should be good if it's not anywhere near the strut tower then. Everytime I have seen bent strut towers, the result repair caused camber problems. But you in great shape since it's farther forward!
