Post 944 turbo look question
When converting a 944 na to the turbo look, can the regular center nose panel be used or do you need to use a 951 nose panel. I'm not sure if they are the same or not.
Thanks for your replies
Old 06-09-2001, 11:26 PM
wolfrpi's Avatar
Post
Ask Otto - he has done it. Yes the nose panels are different as is the headlight covers and just about everything else on the front end.
Erick
Old 06-10-2001, 12:06 AM
Post
The parts would not be a problem, I have a 951 parts car with everything on it. I was just curious how much stuff needs to be changed over from the 951.
Old 06-10-2001, 02:40 AM
