-   -   Klunking Noise??? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/12977-klunking-noise.html)
Ron_Loeffler 06-13-2001 03:53 AM
Klunking Noise???
I Would First Like To Thank The Members Here
For All The Help That You Have Given Me The Past Six Months While Restoring My '83 944
She's Almost Done. I Do Have A Question, When
I Shift The Car I Get A Klunking Noise Is It
Something In The Rear End Or Trans Mount? Anybody Have Any Ideas?? Just A Note The Car
Has About 70k On It (original) Thanks
TomH 06-13-2001 05:07 AM
Klunking noises from rear end are usually CV joint related. Lift back end (use jacks, not ramps), and test axles for play. Also, visually inspect for cracked CV boots, and/or leakage.
CJFusco 06-13-2001 09:38 AM
When this has come up in the past on this board, it has ended up being the Clutch. Although not located in the back of the car, the noise that a clutch makes when the rubber center disk is breaking down travels so that it sounds like it is coming from the rear. If you get a rhythmic knocking under accelleration, then chances are it is the clutch.
kukunaokala 06-13-2001 07:48 PM
Drove me nuts too. Did a clutch job and found the center rubber thingie on the clutch broken. Hana pa'a (good luck) and aloha, Neal
Scott R 06-13-2001 08:35 PM
Same here, I redid mine on Neals suggestions and thats the exact problem and symptom that I had. Here is a pic of a blown rubber center clutch:
[img]http:\\members.home.com/sramnit/clutch1.jpg[/img]
[This message has been edited by Scott R (edited 06-13-2001).]
