synthetic vs. dino... again
is there any reason aside from cost NOT to use synthetic? ive heard its 'thinner' than dino oil but cant that problem be solved by using a higher weight oil?
anyone had first hand negative experience with either?
84 944 Non Alcoholic |
Custom User Title
If you are currently using Dino and have leaks, synthetic will REALLY leak.
I switched to synthetic and had an oil leak before with dino. It didn't seem to get much worse if it did, maybe it will soon...
'83 arctic silver 944 n/a Power steering? who needs it! |
Writer/Teacher
a quote from my mechanic: "Synthetic is great, but it always seems to figure out a way to leak."
Sneaky synthetic oil.
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944. |
I don't recommend changing a high mileage car to synthetic due to leaking capabilities. Always switch to synthetics on a low mileage engine, it's best to make the switch just after a new engine break in.
Jack 86 Red 951 - Turbo Twists, otherwise stock for now 83 Black 944 w/86 951 front end - still down and out, but coming back slowly. 02 Altima SE 3.5 - grocery go-getter 00 Yellow Ducati Monster 900i.e. 88 Chrysler Conquest TSi |
would one have a problem switching from synthetic to dino?
Special Edition 924S 1988 <- SOLD! Asking if you should replace that timing belt is like asking if you should re-use a condom that may have in hole in it with a hooker. |
If its the same grade I can't see it leaking more. Search out Mobil 1 15/50, the heaviest grade they make - I put it in a 115K mile S2 with no problems.
Synthetic is a much, much better oil than Dino and will make your engine last longer - bottom line. Advantages include : No or reduced use of viscosity modifiers which are what break down quickest in dino oil and make it go out of grade Better viscosity behaviour over wide temp / pressure ranges : ie its thinner when cold, stays thicker / stands up to higher pressures when hot. Both these things make it a better oil for any engine, old or new. Obviously if you put Mobil 1 0/30 in an old leaky engine it'll leak like a sieve - 15/50 should be fine. Mark
1991 944 S2 (no more, sold it, gone to a good home) 2003 Infiniti G35 Coupe, 280hp, Black |
Mobil1 is recommended?...
'82 928S ![]() '85.0 944 Not Awesome - Being Parted Out
Writer/Teacher
Mobil 1 is the oil recommended by Porsche
But would it be disadvantages switching from synth to dino?
At the factory they told me to change to reduce oil consumption....there is no problem? what grade? I use BP 5W40 synth,also recommended to Porsche....Now they recommend Mobil 1...do you know what this cost at the factory? About $120 6 liters when changing it... The porsche recommended oil is the one that can pay itīs commercial rights,as always.
--------------------------------------------- 85ī5 951 |
How many posters have actually seen, or know of, oil related engine failures in any car? I don't mean abuse, running low of oil, lack of realistic oil change intervals, but real, the engine broke because the oil failed, problems. I'm thinking hard here and there isn't one I can remember. Change the oil reasonably regularly, don't drive hard until the engine has warmed up properly and it will last as long as you own the car. Obviously, other things might/will break, YMMV.
From November 2012; Precision Porsche Specialist Sussex UK, +44 (0)1825-721-205 2001-2012 Gerber Motorsport Inc. 206-352-6911 07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red 08.16.09 1999 Kawasaki ZRX1100. Green. |
Numerous. I've had 2 cars where the engine was just plain worn out - ie low on compression, noisy cams etc. Also some 944s have this tendancy to spin main bearings which quality oil can certainly help to avoid.
When you consider the improved fuel consumption, the need to change the oil less often, and the improved engine life synthetic doesn't cost any more. Economics : Lets say on Dyno oil your engine lasts 180K miles. At 5K oil changes and $15 per change (oil and filter) thats 180/5 x 15 = $540 Synthetic @10K changes and $35 per change (oil and filter) = $630 Over 180K miles you'll spend $16000 on fuel. Save only 1% (and I think it'll be more like 5%) with synthetic and thats $160. Synthetic is cheaper even if your engine life is the same. Then consider half the pollution from used engine oil (it has to be recycled, it doesnt just disappear you know.) A full rebuild on an S2 engine is something like 8K. If you spin a main bearing it's expensive too. I don't know many people who've had their house burn down but I still take out insurance. Mark
Yes, agree with some of that. However, engines wear out anyway, depending on the make and how they are used. The 944 bearing problem seems to be mainly apparent on track use cars. My point is that actual oil-related failures are rare, whether synthetic or dino oil.
Of course, as I have to work in a shop during the day, my idea of maintaining my own cars and yours is way different!!
But...is there really changes in fuel consumption with different types of oil??
I donīt know why if i use dyno,my fuel consumption should be higher...fuel and oil are separate things (suposely),if you can illustrate me.... And if switching to dyno makes me to reduce at least a 10% oil consumption,no matter if i have to change oil more often,but it will be cheaper. If in the factory told me to use dyno because of the leaks and the oil consumption,they would know what are saying...and dont forget we are using engines designed about 20 years ago,when synthetic is not so usual.
