Angry Questions on a 944 clutch job
I am having trouble with the release lever shaft. I have removed all but two of the bell housing bolts and I have removed the release lever retaining bolt. Now I am tackling the seized release lever shaft but its being a pain in the ass and not budging a bit. I might try a torch but I want to know if anyone has had this problem before and found a good salution.
Cael
Old 10-19-2003, 11:47 AM
SoCal Driver's Avatar
Lots of penetrating spray!
And a slide hammer.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 10-19-2003, 02:54 PM
Scott R's Avatar
I used a length of copper tubing that was larger in diamater then the rod. I then put the bolt with a few washers through the pipe, this created an extractor and it pulled the tube right out.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 10-19-2003, 05:15 PM
thanks
thanks for the help.
pin extracted and clutch job successful.
Old 10-30-2003, 08:36 PM
