Question Rear shock replacement?
My newly aquired 86 951 needs its rear shocks replaced, badly. The car is lowered and it's impossible for me to see what shocks are installed from my garage floor.
I was browsing through a Vertex Auto catalog and there are three different brands of shocks listed for the 944/951, and it appears that depending on how the car was originally equipped you can or can't mix and match? I'm soooo confused.
1986 951, Alpine White
2000 Pontiac Trans Am Convertible, Maple Red Metallic
2002 Jeep Liberty 4x4, Patriot Blue
Old 09-30-2003, 09:30 AM
Mine has Koni shocks on the rear. They can only be adjusted by removing the bolt. Rears are red.
The front also has adjustable Koni shocks. They can be adjusted with a little wrench. Fronts are yellow.
This combination works well on my car.
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 09-30-2003, 09:33 AM
Rear Konis should be Yellow for Sport (Porsche oe fit).
Red are Touring D, not oe fit.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 09-30-2003, 10:10 AM
I installed the rear Koni yellows which are firmer than the reds. I wasn't aware the reds were not oe fit. One minor tip - when I installed the rears, I tightened the upper nut before aligning the lower hole...it was an inch off so I just pushed it into place and put the bolt through. Now, every time I go over a small bump, the shock squeaks. I suspect its because I force aligned the bottom as opposed to positioning it corrrectly to begin with. I have to go back and loosen everything to eliminate the squeak (I hope).
'90 S2 Cabriolet
Old 09-30-2003, 01:58 PM
More info -- it struck me to turn the wheel to full lock to get a gander at the front struts. They have a yellow dust boot (at least it appears to be yellow, very faded). What little I could see of the rears seemed to be metallic.
It sounds like I should go with the Koni yellows (sport)? OE fit and firmer, right?
Old 10-07-2003, 07:49 AM
