Hatch Pin Receiver not moving, Help?
My Hatch has been popping open on the road, usually after some athletic cornering. The last couple of days or so it has only gotten worse (obviously), to the point where the gentle transition into my driveway was enough to promote some open-air action.
After reading some earlier posts I decided to inspect the Pin Receiving mechanisms by opening the Hatch (not too tricky at this stage) and proceeding to twist the key in order to operate the little jaws that clasp the Hatch Pins. I was slightly relieved to note that the left Receiver (the side that won't grab) wasn't even pretending to move, which I would guess points to a fairly minor mechanical failure rather than something more catastrophic. I'm not the most mechanically inclined, but I can definitely follow instructions. If anyone could possibly give me some advice, that would be great, as I would really like to at least diagnose the problem myself if not even perhaps (gasp), fix it! Thanks, Benny |
Might just need some lubrication - use some lithium grease and manually work the mechanism until it moves freely
check the center pivot point that actuate the rods to the latch mechanism. When using the remote hatch release, occassionaly the system will not totally reset and the latch will not fully engage the hatch peg when closed. the body/frame flex causes the mechanism to dis-engage the hatch peg. On by 944, I manually push the pivot(facing forward with hatch open) top part to the right ensuring the mechanism is fully reset to receive and engage the hatch peg.
| All times are GMT -8. The time now is 01:05 PM. |
