ds475's Avatar
Send a message via AIM to ds475
High pitched metal vibration noise
I have this kind of high pitched metal vibration sounding noise, that comes around 3500, without a lot of load on the engine. it's started this just recently.
ideas?
'82 928S
'85.0 944 Not Awesome - Being Parted Out
Old 10-19-2003, 06:43 PM
I'm off the hook.....
Could be the belt tensioner. Would not be a good thing if it seized. Sounds like the bearing is going.
No, I don't sing. Based there for too long.
Old 10-19-2003, 06:57 PM
SoCal Driver's Avatar
Heat shield over the right engine mount.
Then check the other heat shields.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 10-19-2003, 08:42 PM
