-   -   Pics on installing shift boot (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/132263-pics-installing-shift-boot.html)
plandy 10-28-2003 07:48 AM
Originally posted by tclyder
Any other bright ideas?
Hmm, sew a long strand of leather strip around base of boot. Then tie it down to a tight knot around the the funnel base.
Sam Lin 10-28-2003 08:28 AM
Wow, that's a new one on me - my inner shift boots have always been incredibly tight on that metal ring, I've had to warm them up to stretch them onto the metal lip!
Sam
tclyder 10-28-2003 10:52 AM
Do you guys think there is the possibility the PO switch this boot at some time in the past and it is from some other model Porsche?
I believe the 944's used the same boot from '83 through 91.
Tom
:mad:
Sam Lin 10-28-2003 02:17 PM
A new one is about $20, if you'd like to try that - I'd measure mine and let you know diameter, but I'm nowhere near the car. I suspect replacing it'll solve your problem.
Sam
tclyder 10-31-2003 05:06 AM
Do you mean you can get that rubber boot from a porsche dealer for $20? or Ebay?
Tom:)
Sam Lin 10-31-2003 09:04 AM
I've gotten 3 online, 2 through eBay - that's the easiest option for me.
Sam
tclyder 11-04-2003 10:32 AM
I bought a new one on ebay - hope it comes in today so i finally can get it all back together - hope this one will fit correctly
Tom:cool:
tclyder 11-10-2003 05:21 AM
Yeah!
Installed the new rubber boot and it fits perfectly - no doubt the PO had the wrong one installed (thats another reason why the leather boot never fit correctly and always was coming off!
It had to be the wrong boot becauser there is no way iy would have stretched so much at the base.
TOm
Sam Lin 11-10-2003 09:22 AM
That's what I thought also - glad you solved your issue.
Sam
924Sman 11-10-2003 10:35 AM
There is a sound absorbing collar that is missing. It goes over the metal ring I think. 477 711 239....Sman
tclyder 11-10-2003 01:37 PM
Because I probably didn't know any better I used a tie wrap which graps the rubber boot and it is under that metal ring so it is snuggly held in place and will not wiggle off unless the tie wrap would be cut off.
Tom
tclyder 11-11-2003 01:03 PM
I am Almost done
Here is a picture as to where I am At so far.http://forums.pelicanparts.com/uploa...1068584632.jpg
