-   -   1st to 2nd is screwy, and reverse is really weird... (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/132421-1st-2nd-screwy-reverse-really-weird.html)
ds475 10-20-2003 07:27 PM
often times when i go from 1st to 2nd it feels rather "rough" going into gear, then 2nd to 3rd isn't as bad but still feels not like i think it should feel like. kind of like gears grinding a little.
ALSO, sometimes when i try to go to reverse, i push in the clutch and can pull as hard as i want (but i don't) and it won't go into gear, i can push it back to neutral and try again, but it still won't work. eventually what i do, is put it as far as i can in reverse, let out the clutch a little (it will grind a slight bit as i also push the gear back into neutral) then i can finally pull it into reverse.
^^^why does it do this?
is my transmission going?
Rock 10-20-2003 08:52 PM
beats me! but this is similar to what is happening to me.
MrPants 10-21-2003 12:05 AM
when you push the shift lever back into neutral let out the clutch for a second and try it again. some times the gears line up tooth to tooth so they cant get in. i think it means bad synchros.
SoCal Driver 10-21-2003 09:07 AM
Thought you destroyed third gear? Now you are working on first and second?
Mark_944S2 10-21-2003 04:48 PM
Does rough 1st to 2nd co-incide with cold mornings and a cold engine / gearbox? Is it fine when all warmed up?
If so changing gear oil to something thinner might help (ie synthetic)
mark
ds475 10-21-2003 10:38 PM
the gears do that stuff warm or cold, and the weird thing is, it doesn't ALWAYS happen.
