ds475's Avatar
Send a message via AIM to ds475
1st to 2nd is screwy, and reverse is really weird...
often times when i go from 1st to 2nd it feels rather "rough" going into gear, then 2nd to 3rd isn't as bad but still feels not like i think it should feel like. kind of like gears grinding a little.
ALSO, sometimes when i try to go to reverse, i push in the clutch and can pull as hard as i want (but i don't) and it won't go into gear, i can push it back to neutral and try again, but it still won't work. eventually what i do, is put it as far as i can in reverse, let out the clutch a little (it will grind a slight bit as i also push the gear back into neutral) then i can finally pull it into reverse.
^^^why does it do this?
is my transmission going?
'82 928S
'85.0 944 Not Awesome - Being Parted Out
Old 10-20-2003, 07:27 PM
beats me! but this is similar to what is happening to me.
86' Porsche 944 N/a
Old 10-20-2003, 08:52 PM
MrPants's Avatar
when you push the shift lever back into neutral let out the clutch for a second and try it again. some times the gears line up tooth to tooth so they cant get in. i think it means bad synchros.
84 944 Non Alcoholic
Old 10-21-2003, 12:05 AM
SoCal Driver's Avatar
Thought you destroyed third gear? Now you are working on first and second?
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 10-21-2003, 09:07 AM
Does rough 1st to 2nd co-incide with cold mornings and a cold engine / gearbox? Is it fine when all warmed up?
If so changing gear oil to something thinner might help (ie synthetic)
mark
1991 944 S2 (no more, sold it, gone to a good home)
2003 Infiniti G35 Coupe, 280hp, Black
Old 10-21-2003, 04:48 PM
ds475's Avatar
the gears do that stuff warm or cold, and the weird thing is, it doesn't ALWAYS happen.
'82 928S
Old 10-21-2003, 10:38 PM
