Question Just a few Questions
Hi,
I just had a few questions about my 86 porsche 951. First off what is the bolt pattern and the wheel offsets? Second which cylinder do you guys run your egt probe in? location and distance from cylinder head? Third anyone who races these cars can you tell me if the lemans body panels bolt to stock locations or do you need to run a tube frame chassis.
thanks
Old 07-05-2001, 02:17 PM
wolfrpi's Avatar
Post
I put the egt in #4 - closest to the firewall and about 2" away from the head.
Erick
Old 07-05-2001, 02:27 PM
Post
The bolt pattern is 130mm x 5. I think the offset is 52mm but someone with a 951 should conferm that. as far as your other questions. i cant help you there
If you drive it, Race it
Dave
'87 944
Old 07-05-2001, 03:13 PM
Post
The offset is 52mm for '87 and later. For '86 the offset is 23mm.
Old 07-05-2001, 06:00 PM
