How to remove center instrument cluster on early 944?
Hello,
Another beginner question here ... as I posted last week, I need to hunt down a short in my instrument lighting circuit.
Part of the job I plan to do involves removing/replacing the bulbs (also inspect the wiring) in the center instrument cluster.
I've removed the two phillips head screws at the top of the face plate. However, from here (I know this sounds elementary), I'm a bit stuck.
I don't want to start prying things that were not meant to pop loose. Also want to avoid scratching the heck out of my face plates.
Any ideas/suggestions?
Many thanks!
Regards,
DL
84 944 5spd
Maint. & Fixes made thanks to the help received on this board:
Rear Hatch Pins, Oil Change, Dash Cover Installation, New Rear Seat, New O2 Sensor, New Ignition Switch, New Fuel Pump Relay, Rear Light Assembly Reseal, Instrument Panel Short Circuit, New Speedo Cable, New Timing belts and Starter.
Old 10-25-2003, 10:08 AM
MrPants's Avatar
all the knobs on the heater control panel pull straight out, then the panel itself is only held in on the top by some tabs. just pull it out by the bottom. the actual main panel is kind of a beeyatch. i dont know of any good way to get it off. you just have to pull it out by the top.
whats the problem with the console?
84 944 Non Alcoholic
Old 10-25-2003, 11:27 AM
Well, before my short circuit problem, the heater control area was always dark, thus I'm thinking there must be a burned out bulb in there somewhere.
There IS a light behind there right?
Regards,
DL
84 944 5spd
Old 10-25-2003, 03:56 PM
SoCal Driver's Avatar
The heater control panel is supposed top be held in at the bottom with two screws. You have to use a stubby screw driver to reach them. They are just above the radio. Pull the sliders and fan knob off. There are two more screws for the top panel behind the heater control panel.
Don't mix up the light bulb holders as there is a certain one for the light on the heater control panel.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 10-25-2003, 04:53 PM
MrPants's Avatar
there is a bulb on the right side of the heater control panel. i think thats the only one. ive actually got an extra light bulb in mine. let me know if you figure out whats goin on with yours
Old 10-26-2003, 01:30 AM
