Need odometer gear!!
Well, driving around yesterday I noticed that my odometer has quit working..........yeay. So, last night I took it all apart and noticed that the gear that's kinda amber colored that rides on the gear that looks like it has threads that stays in the cluster, is stripped. (It's the only one that is not white.)I've heard about other people having problems with this, but I was wondering if I could get just the little gear and not the whole cluster. Everything else in there looks fine, just need that one gear. It can be used if it's of good quality if any of you have any old parts cars. It's actually pretty easy to get to. I had it all apart in like 15 minutes. Thanks in advance.
Chris
1985.5 Porsche 944 stone gray metallic/tan Full Bursch Tuned Exhaust, SFR Stainless braided fuel lines, Weltmeister Chip, K&N cone filter, Jacobs Ultra Coil & Energy core wires, Bosch Platinum +4 spark plugs, short throw shift kit, 160 thermo, Weltmeister throttle responce cam. |
i ordered that gear online from http://www.klaindustries.net/
it worked for a while but my odometer has quit on me again, i don't know if its the gear or not, haven't opened it up again.
85.5 944 NA |
Alright thanks. I'll have to try it. It had a bunch of teeth in the teeth of the other gears in there that I had to clean out to let it turn again. That may of been your problem too. If there's other teeth in there it won't let it turn past there. Thanks alot.
Chris
