scheistermeiste's Avatar
Send a message via AIM to scheistermeiste Send a message via Yahoo to scheistermeiste
Angry part # needed
i need the number to the adjusting strut for the alternator a/c belt. i had my eye bolt welded back on but it snapped again right bellow the weld. the front bolt i put back in snapped again too. grrrrrrrr but i have the part number for that.
Special Edition 924S 1988 <- SOLD!
Asking if you should replace that timing belt is like asking if you should re-use a condom that may have in hole in it with a hooker.
Old 10-28-2003, 10:39 AM
wait a minute... i just looked in the haynes manual at the ac compressor and it looks different than the one on my car. the one in the book on the bottom has only one mounting hole for the adjusting strut. the one on my car has a place on the bottom at the back that looks like it could also be bolted to something. anyone know if this is the right compressor? could this be why i keep snapping things?
Old 10-28-2003, 10:43 AM
never mind... it looks the same im just special.....
Old 10-28-2003, 11:45 AM
Check the mounting bolts on top of the compressor. You will need to pull the air box and alternator off to see them. The rear one was broke off on mine and the compressor vibrated and kept breaking the strut.
Old 10-28-2003, 03:11 PM
ehh
ehh to me its easier to go from the bottom. ive been under there a few times playing with this. i finally priced the bolts and strut. the bolts i put in ther last time werent strong enough and snapped. this time im just going to buy a new strut and bolts from the dealer. not too bad but i have to wait till i get paid to get a new strut and the bolts. once i get those im ganna replace them and the ps belt and the drive belt.
Old 10-28-2003, 05:37 PM
