-   -   Can you tell if my thermostat is in backwards (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/133510-can-you-tell-if-my-thermostat-backwards.html)
clinton 10-28-2003 02:39 PM
Can you take a look at http://www.orderdairy.com/porsche2 and tell if it is in backwards. its near the bottom of the page thanks.
tab tanner 10-28-2003 02:54 PM
No It's in right. the spring should always be faceing the motor you did it correct
robm-951 10-28-2003 02:55 PM
looks correct to me.
clinton 10-28-2003 03:07 PM
thanks for looking . My car still gets hot and im not sure why it runs fine but gets half way to the red is this normal it seems to stay at the half way mark when warm. I have new updated water pump, new stat, the fan comes on,it is bleed. Mabye the radiator is cloged but when i pulled the plug it seemed to come out fast and clean no gunk.
SoCal Driver 10-28-2003 10:18 PM
Just half way to the red? Start screaming when it touches the red and keeps going.
scheistermeiste 10-28-2003 10:43 PM
i had that problem. but my radiator was about 75% clogged. it really scares you when you drive down the road and a separate guages that goes past 280 is pegged!
Britwrench 10-28-2003 11:10 PM
Does it loose coolant? do the fans operate correctly? do you have the correct pressure cap? can you hear bubbling in the expansion tank? as long as everything works correctly, nothing is wrong.
The gauge is only a guide, not really to be trusted.
Yes, you could also install a seperate mechnical gauge.
Check the radiator and make sure it has even temperature all across the core.
clinton 10-29-2003 05:08 PM
I can see bubbling up in the expansion tank but it only does it if i pull the cap off .You think the head gasket is shot or what would this mean.
Britwrench 10-29-2003 05:10 PM
No it means you released the pressure in the system. Unless you do the diagnosis work this is all guessing.
