Question about timing belt tools
Has anyone used this?
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=43993&item=2440366047
I want to replace my timing/balance belt, all rollers/seals, and the water pump. I know that there's a lot of controversy about the Kriket, but I'm mainly wondering about the other tool. Has anyone used that balance bolt/sprocket wrench? Does it do what it claims to do without making the job much tougher than if I had the other two tools? Are these the only special tools that I'll need (I have a basic wrench/socket set and I can buy other basic needed things from a local Sears)?
Thanks,
Swim
'86 951 blk/blk
-968 M030 Sway Bars with delrin bushings
-IceShark headlight kit
-Koni Yellow Sport Adjustable struts and shocks
-225 lb springs up front
Cleaned grounds = happy 944
WTB: 951 black passenger door/fender
Old 11-04-2003, 08:54 AM
ae1969's Avatar
Send a message via ICQ to ae1969
It should work.... but I used a 90 degree long handled needle nose set of pliers..... <10 bucks and it works just fine.
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 11-04-2003, 09:11 AM
Terry Richards's Avatar
You might also check this site out for tools.
http://www.arnnworx.com/Personal%20Web%20Page.htm
Terry R.
1988 944 NA AT Alpine White
1987 944 NA AT Stone Grey
1987 944 NA 5 Speed Stone Grey
1987 944 S 5 Speed Triple Black
Old 11-04-2003, 07:10 PM
Verruckt's Avatar
I just ordered Bruce Arnn's tool set and am very happy with the quality/price of his tools. This along with my krikit, and 2000 dollars worth of Porsche parts, I am ready to rebuild the head and r&r the rings in my poor smoking 924S.
The crashes people remember, but drivers remember the near misses. – Mario Andretti
1991 944S2 Rally #951 Rally-America.com
Old 11-04-2003, 08:12 PM
Scott R's Avatar
I have that exact spanner wrench and it works excellent!
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 11-05-2003, 08:21 AM
Thanks for those kind words guys. Swim, you might consider a flywheel lock or some way to hold the crank enough to remove the crankshaft bolt (~ 160 ft/lbs).
And BTW, I played with polishing Fuchs too and came up with a quick way to do the rim portion (not the center portion) of the wheel. Check it out at my site (ArnnWorx.com).
87 951 (All stock commuter)
87 951 (Saturday night Special)
77 911S (token tail dragger)
83 928S (engine back in from tear down, interior gutted)
....Grasshoppah
Old 11-05-2003, 10:30 AM
