Question about timing belt tools
Has anyone used this?
I want to replace my timing/balance belt, all rollers/seals, and the water pump. I know that there's a lot of controversy about the Kriket, but I'm mainly wondering about the other tool. Has anyone used that balance bolt/sprocket wrench? Does it do what it claims to do without making the job much tougher than if I had the other two tools? Are these the only special tools that I'll need (I have a basic wrench/socket set and I can buy other basic needed things from a local Sears)? Thanks, Swim
'86 951 blk/blk -968 M030 Sway Bars with delrin bushings -IceShark headlight kit -Koni Yellow Sport Adjustable struts and shocks -225 lb springs up front Cleaned grounds = happy 944 WTB: 951 black passenger door/fender |
It should work.... but I used a 90 degree long handled needle nose set of pliers..... <10 bucks and it works just fine.
Alex - PCA Polar Region - Boxster Muncher 86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD www.edmontonhomelife.com www.edmontonrealestate.ws |
You might also check this site out for tools.
http://www.arnnworx.com/Personal%20Web%20Page.htm
Terry R. 1988 944 NA AT Alpine White 1987 944 NA AT Stone Grey 1987 944 NA 5 Speed Stone Grey 1987 944 S 5 Speed Triple Black |
I just ordered Bruce Arnn's tool set and am very happy with the quality/price of his tools. This along with my krikit, and 2000 dollars worth of Porsche parts, I am ready to rebuild the head and r&r the rings in my poor smoking 924S.
The crashes people remember, but drivers remember the near misses. – Mario Andretti 1991 944S2 Rally #951 Rally-America.com |
I have that exact spanner wrench and it works excellent!
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
Thanks for those kind words guys. Swim, you might consider a flywheel lock or some way to hold the crank enough to remove the crankshaft bolt (~ 160 ft/lbs).
And BTW, I played with polishing Fuchs too and came up with a quick way to do the rim portion (not the center portion) of the wheel. Check it out at my site (ArnnWorx.com).
87 951 (All stock commuter) 87 951 (Saturday night Special) 77 911S (token tail dragger) 83 928S (engine back in from tear down, interior gutted) ....Grasshoppah |
