Post Help! Critical failure!
The factory antitheft system in my 87 944NA has decided to cripple the car. How do I permanently disable this system? It never had any problems until the other day in a hard rain it "went off" while I was driving, horn, etc... and now it wont start. I do not have the keys to fit the alarm lock, so I pulled the panel off the inside and jumped the switch to fool it. it worked to get me home but it happened again and now that does not work. I can hear what sounds like a turn signal relay under the pass side dash that ticks for about 30 secs when I try to start it. How does the system disable the car? how can I bypass it? HELP!
Brian
Old 07-15-2001, 12:44 PM
mideastmafia's Avatar
Send a message via AIM to mideastmafia
Post
check in your battery compartement.. there might be a wire there with a fuse in the middle of it.. pull the fuse.
if not, i think the relay is behind the stereo.
SHAUN
Old 07-15-2001, 12:47 PM
Post
i have a pic on how to bypass the system, i took it when i took my computers out to put new chips in...ill post a little later tonight....its not hard...jeff
Old 07-15-2001, 01:21 PM
