vott does ziss do?
I've been wondering if it would be reasonably possible to retrofit a 1987 951 with the newer (88 and up) DME. as of 1988 the DMEs have self-diagnosis (trouble code) capability and I had considered retrofitting if it's not too difficult or cumbersome.
I suppose it's all a matter of how many sensors need to be added or replaced, or if that's even possible but I really would like to give it a go if it is. any ideas? perhaps signore Audaces might want to take a swing at this one too thanks guys
Need to compare the schematics. Can't attest to any differences in the programming. Maybe Wilk's can jump in here.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
vott does ziss do?
that would be a good start. I'll have a looksee over the weekend when I have a bit of time. good point, I forgot about mr. Wilk. he'd be a good candidate for information on this one
btw: any idea on the price of a used '88 (or thereabouts) DME?
Re: Hugh, Motronic (moronic) question
Re: Re: Hugh, Motronic (moronic) question
Bet the first code is "Clean the Grounds!".
My 86 has the mentioned code read out plug in the engine compartment. Do you know what specifically the later DMEs add? I was told by a mechanic in carrboro (nc) who owns two 88 turbo s' btw, that later DMEs would swap in. I have no personal experience though.
Ahmet
Cheers! |
__________________________________
"Bet the first code is clean your grounds" __________________________________ Bet the second is check your vacuum lines
83 944 white w/Boxster wheels Planned mods- custom leather interior, 968 antenna, soundsystem, 968 style rockers, clear sidemarkers
vott does ziss do?
Re: Re: Re: Hugh, Motronic (moronic) question
vott does ziss do?
I'm going to check my car to see if it'll do the trouble code test
vott does ziss do?
that sounds doable. I'll check here locally and perhaps we should post a new thread to ask others if they have a set that they would be willing to volunteer for temporary duty
vott does ziss do?
p.s. good thing you don't need the whole dang ECU
vott does ziss do?
well, whether it flashes a bulb or reads out on a digital display (as with my scantool) the end result is the same. I still have to do the check to see whether it works on the earlier models. the FM says that this was only available from '88 on but we shall see
the tool is (if memory serves) a 9226 or 9228. It has a red LED for interpreting trouble codes and a SPST switch to bypass the Idle stabilizer valve for idle adjustment.
Downside: the DME from that year does not "store" trouble codes once the engine is turned off - you need to read them with the car running. AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann. Ihr Brunnen der nutzlosen Porsche Information |
vott does ziss do?
hmmm. you sure? the DME is supposed to store the codes and only clear them when the battery is disconnected. or do you mean pre '88 DMEs?
The DME on the 968 stores codes after the car is off, but the DME fir the 944 does not store codes.
AFJuvat
AF, don't forget that late 89 and onwards S2 and Turbos have the diagnosis plug for using the Hammer. The blink tester for the old cars was virtually never connected when I worked at the dealership. We just used to connect the car to a "big box" (Bosch) tester. The point of loosing information by turning the ignition off is, to say the least, not ver clever.
From November 2012; Precision Porsche Specialist Sussex UK, +44 (0)1825-721-205 2001-2012 Gerber Motorsport Inc. 206-352-6911 07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red 08.16.09 1999 Kawasaki ZRX1100. Green. |
vott does ziss do?
sooo, Mark. you got a few stock '88 chips laying around??
Agree on the not too clever thing.
You are absolutely right the 89 - 91 do have the provision for the hammer Yes, I have an 88 chip, already making arrangements to ship it to FR Britwrench - seen PST3 yet? AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann. Ihr Brunnen der nutzlosen Porsche Information Last edited by AFJuvat; 11-02-2003 at 02:50 PM.. |
vott does ziss do?
you da MAN!! (sorry, it just came out) thank you very much. how may I repay you?
