Feelin' Solexy
Tishabet's Avatar
Can I get away with retensioning before 1000miles?
Need some advice here....
I replaced all of my belts today, and everything seems to be performing hunky-dory. I've seen various values for how long you should break in the belt before re-tensioning (I think I've seen values ranging from 750 to 1500 miles). Well, I'm planning on going to this belt party thing in CT, and someone there is going to have the cool porsche tension tool, and it would seem like a waste not to take advantage of this opportunity to re-tension my belts. But I also don't think I can put 1k on the car in the next 5 days....although I do like to drive a lot, so maybe 500-600 miles wouldn't be out of the question, plus the event is 125 miles away. So what I'm wondering is, do I really need to wait for 1k on the new belts or can I feel ok about doing it a bit earlier? And if so, how much mileage should I have on my belts as a minimum?
Grant
In the stable: 1938 Buick Special model 41, 1963 Solex 2200, 1973 Vespa Primavera 125, 1974 Vespa Rally 200, 1986 VW Vanagon Syncro Westfalia, 1989 VW Doka Tristar, 2011 Pursuit 315 OS, 2022 Tesla Y
Gone but not forgotten: 1973 VW Beetle, 1989 Porsche 944, 2008 R56 Mini Cooper S
Old 11-09-2003, 03:53 PM
..P ..P is offline
my mechanic replaced my S2 belts and said to come back in 2000 miles. He said I would have to leave the car, because it would have to sit long enough to be cold when the tensioning was done.
Hope that helps.
P
1983 928S 5-speed, 1984 944, 1990 944S2 Cabriolet
My other car is a Chris Craft Commander
http://www.chriscraftcommander.com
Old 11-09-2003, 04:58 PM
AFJuvat's Avatar
You can get by a little early.
The actual published standard is 1K - 2K miles before retension
That said ..P is absolutely correct. the engine does need to be stone cold before doing a belt check.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 11-09-2003, 05:38 PM
Hey I thought that the 1987 and newer ones with the auto tensioner did not need to be retensioned after a certain mileage?
That is what my friends mechanic said years ago with his 944S2.
Eric
82 924 restored, 83 944 parting out
In search of 1988 or newer nice 944.
Old 11-10-2003, 12:08 PM
entertaining the idea
UconnTim97's Avatar
What is a good time to get the belt retensioned after installing it. I ask, because my belt was installed last November, and I've only put 600 miles or so on it. I probably won't get to the 1000 miles until January. Do I need to have it retensioned before then?
There are some who call me... 'Tim'.
a well set-up 1983 Guards Red 944
Old 11-10-2003, 02:10 PM
Manute's Avatar
600 miles per year?? Wow,less than me.....
And before you retensiones it at 2k miles,itīs needed to retension it more,or you last till the next belt change?
85ī5 951
Old 11-10-2003, 02:55 PM
