SuperDave's Avatar
Send a message via AIM to SuperDave Send a message via Yahoo to SuperDave
almost got it!!!!!
ok now im running into this problem.. replaced the fuel pump and the DME relay.... i can crank it.. it will start.. run for about 2 seconds and then die..... repeat procedure and it will do it all over again... with someone cranking it i can feel the pump.. it is running and when the engine dies the pump stops... what can this be??
85.5 944 N/A, auto
Old 11-10-2003, 05:07 PM
SuperDave's Avatar
please guys.. just got done searching through 824 threads and the one that sounds like mine wasnt completed
85.5 944 N/A, auto
Old 11-10-2003, 05:41 PM
did you change your fuel filter?
Old 11-10-2003, 05:43 PM
SuperDave's Avatar
yes.. the fuel is flowing.. when i try to start it it will start for a second... after that if i disconnect the fuel pump then it will run till the pressure bleeds down and the car dies.. but if i plug the fuel pump back in it will run for a sec then die
85.5 944 N/A, auto
Old 11-10-2003, 05:46 PM
when the engine dies the pump stops? does the pump still have voltage to it....when the key is on? maybe your loseing power to the pump via the ing. switch....i have to wiggle mine to get the radio to work...
1988 924s mars red
coastal cruzer
Old 11-10-2003, 06:01 PM
SuperDave's Avatar
the pump is supposed to stop when the engine stops from what i understood from another post...
85.5 944 N/A, auto
Old 11-10-2003, 06:10 PM
i believe that the pump pressurerises the fuel system but not pump fuel when the engine is off, but the key is on.... check all electrical and think back why you thought to replace the fuel pump you may have over looked something simple....remember air+fuel+spark=bang....car runs...you said it starts,you got spark.you got fuel..check air??
1988 924s mars red
coastal cruzer
Old 11-10-2003, 06:26 PM
SuperDave's Avatar
the old fuel pump was locked up.. the P.O. let it set for over a year with the pump bad.. . but if you unhook the power going to the fuel pump it will start and run for a good minute till the pressure bleeds down after it has pressurized the system
85.5 944 N/A, auto
Old 11-10-2003, 06:38 PM
SoCal Driver's Avatar
Fuel pressure regulator.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 11-10-2003, 07:03 PM
SuperDave's Avatar
thats what i was thinking... thanks guys! did that car fax report.. thios car has been driven 8,000 miles since 1997 and i bought it from the original owner with 103,000
85.5 944 N/A, auto
Old 11-10-2003, 07:06 PM
SuperDave's Avatar
ok replaced the fuel pressure regulator.. still doing the same thing... whats next?
85.5 944 N/A, auto
Old 11-11-2003, 12:54 PM
85944na's Avatar
Send a message via ICQ to 85944na Send a message via AIM to 85944na
will it run if you keep on the gas, or will it die anyway?
PORSCHE: NOTHING EVEN COMES CLOSE
Early 85 G-red 944na, S2 transmission, Ice Shark grounds, Cibie E-Code lights, turbo rear valance, 924S gauges, Turbo S full power seats, "Porsche" door handles, Enkei Wheels.
95 Infiniti G20 dark red metallic-for sale soon
87 BMW 325ic Bronzit, stock(for now)
Old 11-11-2003, 01:41 PM
Other:
DME engine temp sender.
Reference sensor.
Air flow sensor.
Vacuum leak.
Old 11-11-2003, 04:06 PM
SuperDave's Avatar
whether i hold the gas or not still does the same thing... the fuel pump stop when the engine dies.. it stays on after the key is released... my tach bounces when the starter is engaged but works normal when engine starts.. i have found 2 vacuum leaks... 1 fuel pressure damper there are 3 connections.. throttle body, fuel damper and there is another that is disconnected and i cant figure out where it goes.. also if you stand on the passenger side of vehicle and look between the metal intake pipes there is a 2 hose connection plug in connected to a metal tube.. there is nothing connected and i cant see any other connections that might go there
85.5 944 N/A, auto
Old 11-11-2003, 07:51 PM
Me thinks you need to find another post 85.5 944 and do a photo survey so you can fix all this. Too bad you can't review the pictures in the Pelican upload folder. Should be able to find something.
Search for vacuum lines. Might be a diagram still on the server.
Old 11-11-2003, 09:07 PM
P.S. You don't hold the gas pedal down to start a 944. You don't pump it either. It's electronic -- when it works.
Old 11-11-2003, 09:08 PM
SuperDave's Avatar
i was trying for more air into the system.. ya never know what might work lol.. thanks.. ill look through the diagrams
85.5 944 N/A, auto
Old 11-12-2003, 06:35 PM
