-   -   Setting 951 Idle (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/13573-setting-951-idle.html)
threesticks 07-21-2001 05:33 AM
Setting 951 Idle
Can anyone tell me the proper procedure for setting the idle speed for the 944 Turbo?
The Haynes manual tells me to take the car to my dealer. This won't do. I like to do as much to my car as I can.
Thanks, Threesticks.
Lawrence Coppari 07-21-2001 05:43 AM
Manual has some complicated procedure using a CO meter because the CO level has to be set first. Then set to 840 rpm plus or minus 20.
The idle speed is controlled by the little brass screw on the top center of the throttle body housing. I would put some thread locker on it (weak variety) because they tend to move by themselves. Mine came completely out once but remained on throttle body. Lucky......
If you want I could fax factory pages to you on Monday.
[This message has been edited by Lawrence Coppari (edited 07-21-2001).]
Nocturnal_Breed 07-24-2001 11:09 PM
lawrence is there anyway you could email me the pages that pertain to setting the idle on my 951 i also lost the screw and just picked up a new one at the dealer.
my email address is
Nocturnal_breed@yahoo.com
thanks
