first start low idle
whenever i first start up my car, the idles bounces back and forth from about 500 - 800 RPM. It feels like it will almost die...then jump up. But about a minute later, it will idle at about 1000 RPM just perfect. Any ideas? Thanks!
how cold is it where you live?
i'm in south georgia. Its 75 degrees here in November!! LOL
Well then I don't know. My car does that in the morning but after it has been like 30 degrees overnight.
Air Flow Sensor. The double contact wiper on the resistor board has worn away the carbon. You can lower the wiper assembly and move the contacts to a "fresh" area of the resistor carbon.
See http://www.frwilk.com/944dme/afm.htm http://www.frwilk.com/944dme/images/afm_in.jpg |
i just got the car back from the porsche shop...the reason the the car wasn't even running right was because of the air flow meter! so they replaced it with a good but used one. Is the air flow sensor inside the air flow meter box? do you still think it may be that?
how do i get the black cap off of the air flow meter?? does it just pop off?
| All times are GMT -8. The time now is 10:04 PM. |
