first start low idle
whenever i first start up my car, the idles bounces back and forth from about 500 - 800 RPM. It feels like it will almost die...then jump up. But about a minute later, it will idle at about 1000 RPM just perfect. Any ideas? Thanks!
1986 944 non-turbo
Old 11-17-2003, 07:09 AM
MikeCT's Avatar
Send a message via AIM to MikeCT
how cold is it where you live?
1984 944 N/A
1996 Golf Gl
Drive fast. Take chances.
If you can't dazzle them with brilliance, baffle them with bull. - W. C. Fields
Old 11-17-2003, 07:14 AM
i'm in south georgia. Its 75 degrees here in November!! LOL
1986 944 non-turbo
Old 11-17-2003, 07:17 AM
MikeCT's Avatar
Well then I don't know. My car does that in the morning but after it has been like 30 degrees overnight.
1984 944 N/A
1996 Golf Gl
Old 11-17-2003, 07:20 AM
SoCal Driver's Avatar
Air Flow Sensor. The double contact wiper on the resistor board has worn away the carbon. You can lower the wiper assembly and move the contacts to a "fresh" area of the resistor carbon.
See http://www.frwilk.com/944dme/afm.htm
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 11-17-2003, 08:02 AM
i just got the car back from the porsche shop...the reason the the car wasn't even running right was because of the air flow meter! so they replaced it with a good but used one. Is the air flow sensor inside the air flow meter box? do you still think it may be that?
1986 944 non-turbo
Old 11-17-2003, 07:19 PM
how do i get the black cap off of the air flow meter?? does it just pop off?
1986 944 non-turbo
Old 11-19-2003, 02:56 PM
