-   -   Turbomasters revisited (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/13628-turbomasters-revisited.html)
wolfrpi 06-25-2001 03:40 PM
Well I fixed the problem...here are the symptoms - take a guess what the fix was...
BTW: the cut-out was so abrupt the rear tires would actually screetch
at 15 lbs boost car dies in higher rpms (not sure of rpm as things get real blurry accelrating that fast)
at 7lbs the car dies at 6200 rpm - exactly and every time no matter what gear
at 12 lbs the car dies at 4600 rpm - exaclty and every time no matter what gear
at 12 lbs and a 5 psi increase of fuel pressure (via FPR) car dies at 4200 rpm.
So what was it?
Hint: I fixed it in less than a minute
lordgrommit 06-25-2001 06:01 PM
ok what was it ?
Matt
wolfrpi 06-25-2001 06:09 PM
I can't give it up that easily - I spent most of the days and nights of last week thinking about it...lol
Erick
Porsche 951 Fanatic 06-25-2001 07:22 PM
too rich?
Blackfoot 06-25-2001 07:30 PM
those "exactly's" indicate electrical/ignition, right? fried aftermarket chip?
http://home.pacbell.net/nirky/turbo_120.jpg
kaffine krazed 06-25-2001 08:06 PM
A disconnected vacuum line?
wolfrpi 06-25-2001 08:31 PM
DME relay...if you can believe it. I guess it couldn't support the current the S2 fuel pump demanded at high volumes.
Erick
John951 07-27-2001 09:30 AM
OK but once you discovered the DME problem, how'd you fix it?
Drago 07-27-2001 09:38 AM
Uh...replaced the relay?
1986 944 NA
marksportcts 07-27-2001 11:21 AM
Yeah, how did you fix it? Is the relays all the same or is there a stronger one that can take more current? Or did you put a new relay in the back? I am running a Walbro 255LPH pump in my car, supposedly much more flow than the stock N/A pump.
wolfrpi 07-27-2001 01:15 PM
The updated part is a 993 part # - should be stronger than the old 951 part
Erick
