fty fty is offline
fty's Avatar
Send a message via AIM to fty
Question How would I go about stiffening up the rear?
How could i stiffen the rear end..I have eibachs up front and the rear is lowered but still loose as a goose...would konis do it? What is the most inexpensive waay I could tighten the back up like a rock...I could careless about comfort levels...-thanks in advance-chris
"Faster,Than,You"
"Wish I had a 951....."
"Ive tried so hard and got so far but in the end it doesnt even matter"
http://www.members.aol.com:/fty9999/944land/944land.htm
Old 08-05-2001, 08:54 AM
Bob's944's Avatar
Send a message via AIM to Bob's944
Just shocks isn't goin to do it, u need to go to larger(fatter) torsion bars to get the same effect as stiffer springs in the front. There is a hollow design that is lighter and has the effectiveness as fatter solid bars. That's still down the road for me, Koni's are in one of my phases of modifations too.
Old 08-05-2001, 09:10 AM
1.2gees's Avatar
Send a message via AIM to 1.2gees
Post
Actually shocks can also increase rear roll stiffness, though that may not be the best way to do it.
I'd get an adjustible rear sway bar, along with shocks. Keep in mind that a hollow torsion bar will NOT reduce unsprung weight, therefore may not be worth the $. And it's probably not worth the trouble to change it out.
Ahmet
It's all the driver...
My page over1g@hotmail.com
Porsche owners Gallery.../My 944
Old 08-05-2001, 02:18 PM
Post
If your rear is loose, you need less rear sway bar. An adjustable rear bar would allow you to soften it, which will plant the rear tires more.
Insted of doing that, i'd get an adjustable front bar. If you stiffen up the front, you'll increase rear traction without loosing overall roll stifness.
The general rule is, you need to increase roll stifness on the end that is NOT sliding. I.E. if you have a car that understeers, you need a stiffer rear or a softer front, if it oversteers (your case) you need a stiffer front or a softer rear.
Mike
Old 08-05-2001, 07:05 PM
Post
fty- when you say the rear is loose, do you mean there is a lot of roll/travel during cornering, or do you mean that the car is oversteering/sliding out?
I assume you mean the car has excessive roll since you asked how to stiffen up the rear. This will increase oversteer.
Dave Harrington
Old 08-05-2001, 08:52 PM
