Ornery Bastard
Odd clutch question...
If I depress the clutch pedal during hard braking (or during normal braking on a steep up-hill) then the clutch pedal goes almost to the floor. There is perhaps a half-inch to three-quarters of an inch of travel left before the pedal is fully on the floor and the entire operation of the clutch happens within that last bit of travel. In other words, what seems like 85%-90% of the pedal travel becomes "free play" with full operation occuring in that last 15%-10% of pedal travel. The clutch will still completely disengage, even when this happens, but I'm sure you can see how this is an annoyance (and a slight hinderance since it makes it very hard to be smooth when this happens).
My first thought was a bubble in the lines that was moving around during braking, but I have just had the system purged and re-filled to no avail. The slave and master cylinders have less than 30,000 miles on them and are not leaking. Anyone have any ideas on this? Should I perhaps bleed both the clutch and the brakes since they share the same reservoir? Thanks in advance. Aaron
--------- Silver 1998 Volvo S70 T5 <- Daily (Anja) Guards Red 1986 951 <- Seattle car (Gretchen) White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei) |
Sounds like the clutch cylinders are bad. If you have recently replace just one of them then it's time to replace the other. Also the woven hose that comes off of the brake reservor that feeds the clutch hydraulics tends to leak and cause air bubbles.
Still my clutch has always had a sone what long travel.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
Ornery Bastard
This is almost enough to make me miss the cable clutch in the 914 though. Much simpler. Aaron
Two possibilities I can think of.
1-One of your hydraulic lines have a small air leak. 2-Either your clutch slave or master are bad. I'm not being obtuse. I read they are less than 30,000 old but my newly replaced master cylinder went bad within a year (6,000 miles). I figured although it was new, sitting on a stock shelf for several years turned the new seals brittle.
-Dave- 1969 911/3.0l SC |
Ornery Bastard
Thanks guys. Aaron
