Headlight Problem
Ok guys Rock is having another problem. Here it is.
I was driving home and both of my headlights were out. I went up and smacked them a few times and they both went on. Then the drivers side one went off. So i had to drive home with my brights on. When i got home and turned my brights off, both of the lights were off. So i smacked them again and they turned on. Is the bulb dying, or is some wiring going bad or something?
86' Porsche 944 N/a |
try bulb grease on contact ends
944 guards red 82- slotted rear turbo spoiler- new dash cover- red dials - k@n dropin filter- throttle cam upgrade- astrali wood steering wheel {can now see temp guage}-(www.astrali.co.uk)blue/white fogs {RING}-reversing sensors-alpine cd-roil gold engine protection |
Bulb grease???
Babblefish couldn't translate that one.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
Try cleaning the contacts where the bulb joins the socket attached to the car. Next apply some grease to the contact blades on the bulb, this should prevent rusting of the metal contacts.
At the same time you can inspect the wires to see if they are brittle - if so replace People from the Wirral generally talk back to front ![]() tr: try grease on bulb contact ends Babelfish Schmabelfish
(x)'89 944 S2 Cabriolet (Guards Orange) : ( )'90 944 S2 (Maraschino Dead!) : ( )'89 Audi 90 Quattro 2.3 20V : ( )'92 Renault Clio 1.4 : * |
Ornery Bastard
Aaron
--------- Silver 1998 Volvo S70 T5 <- Daily (Anja) Guards Red 1986 951 <- Seattle car (Gretchen) White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei) |
Your relay may also be going bad.
Samm--It's short for Samantha... Keystone Heights, Florida Florida Crown Region--PCA 2006 Acura RSX 1984 944 Track Car 1972 914/6 Race Car |
Ornery Bastard
I've been wrong often before though. Aaron
The current for the head lights does not go through the relay on the headlight motor.
There is a relay in the fuse box for the low/high beams that is opperated by the latching switch inside the steering column lever assembly. Since you are hitting the front of the car and not the steering column or the fuse/relay box I would check the grounds to the chassis behind each headlight and all of the flexing wires from the chassis to the headlights including the plugs on the headlights.
I second for grounds or loose wire...
the "smack-it" test is usually good for that.
83 944 white w/Boxster wheels Planned mods- custom leather interior, 968 antenna, soundsystem, 968 style rockers, clear sidemarkers
There is the relay for the light motor. I had the same problem with my old car.
yea there is another relay on the side of the headlight motor. there is also a 3 wire connector that you might want to check for corrosion.
84 944 Non Alcoholic |
Ornery Bastard
Aaron
