-   -   Power window won't go all the way (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/139670-power-window-wont-go-all-way.html)
Zeloy 12-14-2003 03:29 PM
My power window goes up, but stops when there is about 1/4 inch to go. It's so dissapointing when it tries so hard but doesn't make it all the way! :( I have to push it up the final 1/4 inch. Is this likely a problem with the motor, or is the window slightly off track? Any suggestions on how I could fix this myself?
ronin 12-14-2003 04:54 PM
damn, FR beat me to it
best way to start to check is to remove the door panel and try moving the window several times to see if it is binding in any way
bearone2 12-14-2003 06:54 PM
make sure the window is in the channel on both ends for the whole travel range.
the channel that the window rides in, front/back could have something restricting movement but you said you can pull it up.
the channels can be r&r'd without removing the window if you have to replace them.
SoCal Driver 12-14-2003 08:21 PM
I've had the quarter gear break loose from the arm that raises the window. Three or four spotwelds.
turbohead7 12-14-2003 08:21 PM
Window woes
You may find that you have a problem with the motor or the regulator. You musr R+I the door panel and watch the window operation to diagnose it.
