Power window won't go all the way
My power window goes up, but stops when there is about 1/4 inch to go. It's so dissapointing when it tries so hard but doesn't make it all the way! I have to push it up the final 1/4 inch. Is this likely a problem with the motor, or is the window slightly off track? Any suggestions on how I could fix this myself?
Old 12-14-2003, 03:29 PM
vott does ziss do?
ronin's Avatar
damn, FR beat me to it
best way to start to check is to remove the door panel and try moving the window several times to see if it is binding in any way
Old 12-14-2003, 04:54 PM
bearone2's Avatar
make sure the window is in the channel on both ends for the whole travel range.
the channel that the window rides in, front/back could have something restricting movement but you said you can pull it up.
the channels can be r&r'd without removing the window if you have to replace them.
87 951, K27/6, Almond Beige, 17" Turbotwist
87 944S, alpine white, 5sp died a violent death
84 944, silver/brown, auto, gone but not forgotten
"may the force be with you"
Old 12-14-2003, 06:54 PM
SoCal Driver's Avatar
I've had the quarter gear break loose from the arm that raises the window. Three or four spotwelds.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 12-14-2003, 08:21 PM
turbohead7's Avatar
Window woes
You may find that you have a problem with the motor or the regulator. You musr R+I the door panel and watch the window operation to diagnose it.
Even though I drove a GT2, I still love my 944.
