944/951 Odometer not working? Get you update here! ;)
I got some power steering rack seals from Rennbay. I think he still post here. Well I was just checking out Ebay and I seen the odometer gear for sale. I need this item. :D
Also check out his site for other stuff he's selling. http://www.rennbay.com/index1.html Here's his auction. Quote:
http://i23.ebayimg.com/03/i/00/99/0b/9a_1.JPG http://i23.ebayimg.com/03/i/00/99/0b/b5_1.JPG |
Note: This is for 85.5 and newer.
does anyone you know cary odometer gears for 84 944's
i think rennbay carries those as well.
the only one listed for a 944 was from 85.5 on
I got mine .. but not installed yet .. this sat I will try to do that .. !
helluva bump..
anyway, i pulled the speedo out and for the life of me i couldn't open the bloody thing to get to the internals... |
you either have to cut the black ring off with a file, or what i did was use a very small screwdriver and pry the the back of the ring up all the way around, carefully, and it will come apart. the ring is brass that is painted black. if you do this carefully, you won't even be able to tell it was apart.
cool..
i thought i tried that.. who knows - maybe a previous owner glued the mofo down... i shall try again. so the black brass ring is folded around the casing? what screwdriver would be small enough to do the job, but strong enough to withstand the prying of the brass? time to go digging through the old tool box... |
eldorado, did you get the gear from rennbay.com?
i actually didn't get a gear... it just recently stopped working when the PO had it (i know him personally) and he says he never pushed the reset button when it stopped so i'm hoping *crosses fingers* that the gear has just slid down the shaft slightly and lost contact with the other gear.
| All times are GMT -8. The time now is 02:33 PM. |
