88_944's Avatar
944/951 Odometer not working? Get you update here! ;)
I got some power steering rack seals from Rennbay. I think he still post here. Well I was just checking out Ebay and I seen the odometer gear for sale. I need this item.
Also check out his site for other stuff he's selling.
http://www.rennbay.com/index1.html
Here's his auction.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=2448057753&category=33678
Description
This is a updated odometer gear for all late model 944 and 951. If your odometer does not work the likely culprit is a broken odometer gear. The stock gears supplied by VDO break down over time and fall apart. These new odometer gears manufactured by Rennbay inc. are made of an ABS blend that will not break down and crack. These gears are precision injection molded to perfect specifications. It's an easy fix that will have you counting the miles again in less than an hour. All gears come with a new E clip, slip washer and they have the spindle pre greased. This is for the US spec models with MPH listed on the speedometer.
My Black 944
My Gaming Forums. Xbox360gen.com
Old 12-17-2003, 02:52 AM
SoCal Driver's Avatar
Note: This is for 85.5 and newer.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 12-17-2003, 05:20 AM
does anyone you know cary odometer gears for 84 944's
84 Porsche 944..its why im here
95 Ford F-150
98 Jeep Wrangler TJ
Double 0 Alero. Alright! something from this millenium
Old 10-19-2005, 11:01 AM
winter-hater club member
nynor's Avatar
i think rennbay carries those as well.
"COOL PRIUS!" - Nobody Ever
Old 10-19-2005, 11:11 AM
the only one listed for a 944 was from 85.5 on
95 Ford F-150
98 Jeep Wrangler TJ
Old 10-19-2005, 11:19 AM
Tapage's Avatar
Send a message via ICQ to Tapage Send a message via AIM to Tapage Send a message via Yahoo to Tapage
I got mine .. but not installed yet .. this sat I will try to do that .. !
David Alonso De La Vega Tapage
Panama
944 Turbo
Old 10-19-2005, 11:36 AM
Eldorado's Avatar
helluva bump..
anyway, i pulled the speedo out and for the life of me i couldn't open the bloody thing to get to the internals...
Kyle
2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] //
"Never break more than you fix!" - SoCal Driver
Old 10-19-2005, 11:44 AM
nynor's Avatar
you either have to cut the black ring off with a file, or what i did was use a very small screwdriver and pry the the back of the ring up all the way around, carefully, and it will come apart. the ring is brass that is painted black. if you do this carefully, you won't even be able to tell it was apart.
Old 10-19-2005, 12:48 PM
Eldorado's Avatar
cool..
i thought i tried that.. who knows - maybe a previous owner glued the mofo down... i shall try again.
so the black brass ring is folded around the casing?
what screwdriver would be small enough to do the job, but strong enough to withstand the prying of the brass? time to go digging through the old tool box...
Kyle
Old 10-19-2005, 01:32 PM
eldorado, did you get the gear from rennbay.com?
95 Ford F-150
98 Jeep Wrangler TJ
Old 10-19-2005, 02:09 PM
Eldorado's Avatar
i actually didn't get a gear... it just recently stopped working when the PO had it (i know him personally) and he says he never pushed the reset button when it stopped so i'm hoping *crosses fingers* that the gear has just slid down the shaft slightly and lost contact with the other gear.
Kyle
Old 10-19-2005, 02:25 PM
