-   -   What is it and what does it do? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/140100-what-what-does-do.html)
TCMdocs944 12-17-2003 02:22 PM
Small metal cylinder
on back of airbox
two electrical connections
vacuum hose in, vacuum hose out.
#2 Is the wire ground closest to the tower or the manifold?
SoCal Driver 12-17-2003 03:05 PM
Valve for the charcoal gas fumes filter canister.
todwic 12-17-2003 05:22 PM
No, that's the A/C "extra air in to compensate for the drag of the A/C belt thingy".
todwic 12-17-2003 05:24 PM
"extra air in to compensate for the drag of the A/C belt when you turn the A/C on thingy" I mean. I'm assuming that the car came out with A/C.
TCMdocs944 12-17-2003 05:30 PM
Yes indeed ----A/C a must in Florida.
So......If it wasn't working I would get a significant rpm drop at idle when the a/c cycles on...
Yes......
Ground closest to the shocktower?
TCMdocs944 12-17-2003 05:31 PM
Oh yeh Todwic....I assume A/C comes standard in the 3rd plane of hades.
......If you know the right people.
todwic 12-17-2003 05:32 PM
aye, rpm drop. If one of em is brown, that's the ground, other than that, I can't really say. Get jiggy w/ voltmeter.
todwic 12-17-2003 05:34 PM
aye, standard. I keep hoping they kick me out for opening up the ice water stand, but I musta been really, really bad.
SoCal Driver 12-17-2003 06:25 PM
I was thinking to far back.
todwic 12-17-2003 06:38 PM
That's what I thought you were thoughtin :cool:
Porsche944 12-18-2003 08:35 AM
Auxiliary Air Solenoid. Energized when the A/C compressor clutch is energized. Allows additional airflow into the intake to compensate for the additional mechanical load from the A/C compressor.
bryanthompson 12-18-2003 09:16 AM
reading the subject line, i just got the theme song for 'will it float' stuck in my head. heh
TCMdocs944 12-18-2003 10:21 AM
New P Jargon from this post..
both work for me
