rough idle when cold
hi, my 87 944na idles rough for the first minute after starting from cold. it also has no power and the engine sputters and acts like it is going to die.
no problems starting ever! no problems after the first minute. my mechanic says that the O2 sensor doesnot kick on until after about a minute or two, so im pretty sure thats not it. and i bet i could unplug it and it would still do it. any thoughts. thanks |
I am having a problem of rough low idle on cold starts on my '86 NA 944 and suspected the idle control valve and was about to replace it. that would have been a lot of work and about $120 wasted.
What I have found with a lot of sudying and testing is this: The idle control valve on my car ('86 na) has 3 posts. On a cold start voltage is suppost to be supplied to the center and top posts which opens the valve to let extra air in to help it idle when cold. As the car warms up power is suppost to be shifted from the top post to the center and bottom posts which closes the valve. Mine is always suppling power to the bottom 2 posts, cold or hot so the valve stays closed hence no extra air on a cold start hence an overrich (actually under supply of air) condition. I can unplug the connector and run 2 wires from my battery and touch them to the top 2 posts and the valve opens and it starts perfect when cold. I can then slide the connector back on after about 30 sec of warming up and it closes it and idles fine. Now I have to figure out why my computer is not swiching power to the top 2 posts when cold. I have already replced the temp sensor with a new one. I assume there is a relay somewhere that swiches this but I have no idea where so I am now at a dead end. I think we have the same problem as do others with a 85.5 and newer 944. [This message has been edited by T86951 (edited 08-13-2001).] [This message has been edited by T86951 (edited 08-13-2001).] |
do you have problems starting?
mine always starts first crank, no problems. |
never a starting problem. Hits and starts first thing cold or hot. and as soon as it starts when cold slow idle trys to quite ,I give it some gas and get a little black smoke and then clears out in 30 secs and is ok.
If the injectors were leaking off it would be flooded and would be hard to start. Not that here. [This message has been edited by T86951 (edited 08-14-2001).] |
where is the temp sensor?
where is the plug you are referring to? |
temp sensor is on the side of the head or block , don't remember which but just under the throttle body. It has a connecter plugged on it.
Dirty mas air flow assy. will do the same thing, initial idle mixture is off and until the warmup sequence is done your idle is rough. As soon as the O2 sensor starts sending info the mix leans out and the condition stops. This is also sometimes the cause of hard starts when the enigine is hot. Just another avenue for you to try.
Thanks for the info. But the thing I don't understand from that is my car starts first hit cold or hot and the voltage doesn't switch to the other post on the idle control valve. I have even thought about putting a pre 85.5 valve , 2 wire and 2 post that I think closes when it warms up. I don't have an answer to this but thanks for providing input on our problem. I know somebody somewhere has figured this out and knows the answer. One thing it never seams to happen with a pre 85.5 model.
dirty? like nasty gunked up sludge or like just a little bit of dust under the black plastic cover can screw things up?
Your idle regulator could be carboned up and causing the valve not to open. Also, if your idle seems to surge back and forth a few hundred rpms then most likely your idle regulator. Have you had your CO and mixture adjusted by a mechanic with a computer?? They will check the O2 sensor as well, to see if it operating correctly. The idle reg is a fairly $ fix as you have to remove intake manifold around $300 part is around $125, labor about 2.5 hours. Have all vac hoses changed while the intake is off
Cold start explained
Anybody tell me how the cold start side of things works on an S2? what does what and were it is
After cureing hesitation {throttle switch} twice in the last week i have started it up from cold and it was runnin on 3 cylinders smokeing like hell overrich. After a couple of minutes it clears Anybody any ideas? Thanks mark |
87 924s
My 87 924s with a 86 engine in it has the same problem. After about 5 minutes the car begins to idle smoothly. I guess the easiest solution is to just let the stupid vehicle warm up.
Yeah it's a twenty year old car. It has some idiosyncrasies that you need to just live with imo.
I just let the car warm up for a couple of minutes. I don't want to stress the manifold anyways. Plus, it goes away soon for hibernation :( |
Did you ever get this problem solved? My 89 S2 is doing the same thing. I've done extensive troubleshooting but still no answers.
Help! Quote:
My S2 does the same thing. Oh well.
Bad Dme temp sensor will cause this if its always reporting a hot engine to the dme (ie sensor stuck/bad)
T86951 I think you have your explanation backwards. Most engines need a richer than stoich mixture when cold (less air) and then more air (lower A:F ratio) once at operating temperature. Unless the 944 idle air valve works differently than a standard choke valve, it sounds like yours might be closed all the time (rich condition all the time).
POP,
I thought the choke valve created a vacuum in the carb Venturi that richens the mixture? The AAV or the ICV allows more air to bypass the TB when the engine is cold. I thought that the DME controls the mixture and makes it rich when the temp sensor is reporting cold. Jackson |
Got a new fuel pressure regulator and pressure damper coming. Will post if it makes any positive changes.
Pull off 1 plug wire at a time, while the engine is exhibiting the cold miss symptom, to determine which cylinder is "misssing". Then swap that fuel injector with one from a different cylinder. If the miss then migrates to the other cylinder, you have just confirmed that you have a leaky fuel injector.
Oh, in the off-chance that the miss stays with the same cylinder after the injector swap, it's likely that you have a valve guide seal that is toast. That is unless a spark plug is fouling, which could be checked in the same manner as an injector. But if it does turn out to be a spark plug, it is likely that one of the first 2 things mentioned is what caused it to foul. |
I haven't tried your suggestion regarding swapping injectors. I'll add that to the list. FPR and damper get here tonight and I'll have them on this evening. Thanks for the advice! |
Replaced FPR and damper. Still have cold start issues! Got another engine temp sensor coming. Pulling at straws here. Anyone want an 89 S2?
i have the same problem on a 86" NA
after hours of work,try,change sensors and so on i change the air/fuel ratio on my AFM. I put 2 to 3 cyrkle in "lean" counterclockwise and the situasion now is perfect. I try to return the hex in the old position and the problem begin again but don't now what can happen. Maybe with years there are lots of small vacuum leaks that change the demand of mixture. Maybe the O2 sensor will have a wrong signal on cold???? Try this,without cost but remember the numbers of cycles so you can go in other direction if is worsth |
This problem is most likely caused by either a bad O2 sensor or a bad DME temp switch. Not the FPR, Damper, Idle valve, AFM or other stuff mentioned.
Check those two things first. The dme temp switch is on the cyl head under the intake manifold at the front. There are two temp switches there, one for the guage one for the dme, it's the dme one you need to test/change. If that doesn't fix it test/change your O2 sensor. Basically those two things will effect idle when cold, all the other stuff mentioned will effect idle cold or hot and if your idle is good hot then you are only left with O2 sensor and dme temp switch. |
Thanks for the suggestions.
I have replaced the DME temp sensor. That made no difference. I have not replaced the O2 sensor yet; I did, however, unplug it. I was told that by taking the O2 signal from the dme, it would use a closed-loop map. And plugged or unplugged made no difference. This problem didn't show up until I replaced a cylinder head. Compression is good and once warm it runs great. It just seems to be a problem that corrects itself when warm. Could this be an issue with the reference sensor? Still scratching my head.....:confused: cds Quote:
I give up!:(
This is looking more and more like one of those threads (stories) where decent amounts of $ are being spent on THIS new part, and THAT new part, only to see the problem NOT go away. It does pain me, to see it going on and on.
YOU NEED TO TROUBLESHOOT THE PROBLEM, MAN! The poke-&-hope approach only seems to be costing you $, but isn't getting any results. If adjusting the idle mixture (air bleed) screw doesn't take care of it, you need to narrow it down to what cylinder is misssing when cold. Intake runner gasket leak when cold maybe? Is the cylinder missing because it's too rich, too lean, or sparkless? Did you say that you checked compression? EDIT: I forgot to mention, it WON'T be the O2 sensor, as that does not even function when the engine is started up cold. And the loop is OPEN (not closed) if the sensor is disconnected, but that's how it operates on cold startups, anyways. |
All right, I really want to help you here, so I am going to add to my last post.
After determining which cyl is the misser, closely inspect the spark plug, as it should show signs indicating whether it is running too rich or too lean. But don't do this after it has been running warmed up without a miss for ANY length of time. If it whitish/dry, it probably too lean due to that cyl sucking in extra air somewhere, or the injector getting clogged, relative to the others.. If it black/wet, it probably rich, but that could be for several reasons. One being that the injector leaks when the engine is shut down. Then when started back up, all of the fuel laying in that cylinder fouls out the plug, until it burns it up. The other thing that could appear to be making it too rich is engine oil. There is the possibility of a head gasket issue, allowing oil to drip into that cylinder, which would cause essentially the same effect as excess fuel in the cylinder on a cold start, fouling the plug until the engine warms up enough to cook it off. A defective, damaged, or incorrectly installed valve seal would also produce the same effect. Ok, I gotta go now. I hope that gives you something to go on. Good luck! |
I've had a similar issue with my '86 where it keeps dropping from edge of dieing, then comes back to life and spikes above idle, then drops back to about half idle. I'm rebuilding the suspension before I drive it, so I haven't fixed it yet.
However, I did notice that my in dash volt meter is is jumping and falling along with the rough idle, first thing I'll do next time I try to sort it out, is put a volt meter under the hood and see what is going on. |
Now THAT really sounds like bad ground(s) somewhere. |
I'll post more when I hear something. chris |
Initially my S had the same problem/symptoms for ~2 months
I changed the to NGK Iridium sparkplugs, New O2 and a bottle of Chervron Techtron and it never did it again. Try this out... Later, |
That's a good idea. I think I will pull my temp sensor and have a look.
That sensor might just be an item that should be replaced/ cleaned every 75,000 miles or so as a preventative measure. |
Gentlemen the problem starts at the temp sensor change it, it will help, also look a frwilk.com web site something to do with the shudder fix code early 944, on his web site look for 944.com
Cylinder head was replaced with a rebuilt unit from Rennbay. Engine temp sensor was replaced. Speed(or reference sensor) was replaced. Hall sensor in the distributor was replaced. Spark plugs were replaced with correct Bosch units. Plug wires ohm'd correctly. AFM was checked to include the air temp sensor inside it and it's o.k. Idle Stabilizer Valve was replaced with a new one. All four fuel injectors were replaced with rebuilt ones. Fuel pump check valve was replaced. Fuel pressure regulator was replaced with new one. Fuel pressure damper was replaced with new one. The engine computer (ECM) was replaced with a know good one. Compression check and leakdown were good. I have followed every troubleshooting procedure in the factory manuals to the best of my abilities. I then took it to a competent mechanic who did the same. He's just as baffled as am I. :confused: Is there anything I'm missing here - other than a for sale sign or a pound or two of C4? The only thing I haven't replaced is the engine wiring harness (because it ohms correctly). Plus, it seems that 1989S2 is one year only so I probably won't have an easy time finding one. Any S2 owners in the Huntsville, AL area? |
Since there is no OBD-2, this is where one of the old fashioned engine analyzers scopes would be helpful to run a power balance test and check the tailpipe emissions. If it happened every time... |
Sounds like the heater in the O2 sensor has failed. Initial 30 seconds is open loop then it requires the heater until the sensor warms up. Once warm the heater is not required. Change the O2 sensor.
It's easy enough to pull spark plug wires to see if it runs "less worse" with one particular cylinder deactivated. You can also use a temp gun to see if one plug or exhaust port is cooler than the rest after it has run badly for a good while. Checking plugs after it's been idling poorly can also tell you a lot.
Then go from there. Injector, intake gasket, vacuum leaks, etc. Since the 944 engine is batch fire it'll compensate for one bad injector pretty well though. |
| All times are GMT -8. The time now is 05:59 PM. |
