Headlight problem - 1983 944
Low beam on left side does not work. I have swapped all 4 fuses
and replaced headlight. Anybody got any ideas on where I can look now? Do the wires go to each side(driver and passenger) independently of each other? Thanks for any suggestions.
Old 12-29-2003, 08:17 AM
Chris_924s's Avatar
Check out the grounds behind the headlight bucket- it's a bundle of brown wires with terminal lugs - clean them off and see if it gets better..
TENSION YOUR SOCKS!
88 924S Guards/ Black ~ 10 years as a Daily Driver and STILL SMILING!
87 NA Diamond Blue Metallic ~ Gone
Old 12-29-2003, 08:32 AM
Did you check the bulb (or sealed beam). The first thing to do is check for 12v and ground at the headlamp. It may be the bulb or a brokem wire in the harness right by the headlamp.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 12-29-2003, 08:47 AM
I put new 'Sealed beam' in and had the same problem, I switched Left side with Right side. There are 3 wires going into bulb - on bight, I get voltage on Low Beam, I get no Voltage. Do I trace wire to other side or does wire to the fuse box?
Old 12-29-2003, 09:47 AM
