Question Possible oil pan leak?
Hey guys long time no talk to! Just moved to eastern TX a few weeks ago. Longview, TX exactly. Only a little over an hour from Dallas so Im interested in getting active with some TX clubs maybe the SCCA & PCA.
Question: 86 951 103,000 easy miles
Problems that I have found:
Head gasket seep at #1 w/o mixing or loss of power
The last service I had indicated that I had an oil pan leak.
Under hard braking I get an oil burnoff evident by a cloud of smoke nurning off the crossover/exhaust.
What do you think and how hard is it to change the gasket?
Thanks guys!
Brock
Old 06-12-2002, 07:39 PM
It is a considerable amount of work. Turbo cross feed pipe has to come off; you have to support engine from above; you might think about changing rod bearings while you are in there; and you might think about engine mounts while there as well. Here are some pix.
Old 06-13-2002, 04:05 AM
Here is one more pix for lower supports. Note how leakage of oil coated the turbo output pipe. The cross pipe was getting even more oil.
Old 06-13-2002, 04:54 AM
