Post windshield wiper motor questions.
A friend is interested in purchasing a late model Turbo S and I am assisting. On this car the wiper blades are stuck in a verticle (straight up) position. The seller indicates that he had it looked at and was told the motor was bad.
I wanted to ask you all if:
1) is this a common type of failure or should we look for another reason, ie. relay, fuse
2) Is the motor the same for the turbos and non turbos.
3) Is this a nightmare repair, or fairly easy.
4) whats a fair price for a used motor.
thanks in advance for any wisdom or responses.
brant
Old 08-27-2001, 02:00 PM
Scott R's Avatar
Post
Two things have happened to my wipers over the last few years. Once the fuse connection in the central electrics box was not holding the fuse tightly. I could wiggle it and get the wipers to come on. Second the relay blew out a bit later. Most likely due to the fuse popping in and out. But test the power to the motor to be sure. I sure would not let something as simple as a wiper issue deture me from getting a S turbo.
Old 08-27-2001, 02:07 PM
Post
Wiper motors on early models aren't but $150-160. 86 on probably about the same. Easy to change.
Buy the car.
drew1
Old 08-27-2001, 02:11 PM
Scott R's Avatar
Post
BTW: The motors usually go between $35 and $40 on Ebay
Old 08-27-2001, 02:13 PM
