Exhaust Leaky
I have an exhaust leak in the 944. Does anybody know how bad this is taking down performance? How much horsepower is lost. I dont know where the hole is... or how big it is... all i hear is a ticking noise that gets faster along with the engine RPM.
86' Porsche 944 N/a
Old 01-03-2004, 09:25 PM
SoCal Driver's Avatar
Gaskets.
Most likely at the head.
Or one of the manifolds is cracking at the point the two tubes come together into one.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 01-03-2004, 09:38 PM
vott does ziss do?
ronin's Avatar
the travails of turbo ownership, for sure
Old 01-03-2004, 11:01 PM
Zero10's Avatar
Send a message via ICQ to Zero10
Uhh rock, yours is not a turbo, you are not loosing exhause pressure on the way to the turbo itself, so you are not losing power. Besides, unless it is bloody loud, and you can see exhaust coming out of it, it is not big enough to make a difference. Check where the pipes from #1 and #4 come together, on the underside (exactly where you can't see it!), that's where mine cracked.
2010 Hyundai Elantra Touring, GLS 5 speed, Indigo Blue Metallic. 2.0L of Korean fury!
Buy my parts!
Old 01-04-2004, 01:02 AM
Sabyre's Avatar
Dont these cars rely on some form of back pressure? Wouldn't an exhaust leak change the characteristics of the back pressure?
"We are the music makers and we are the dreamers of the dreams" -Willy Wonka
Old 01-04-2004, 01:41 PM
Zero10's Avatar
That is accurate, they depend on backpressure, but the amount of pressure lost to the leak, unless it is very large, would not make any measurable difference. In order for it to make a difference it would have to be about the size of a dime or a nickel.
Buy my parts!
Old 01-04-2004, 02:48 PM
