Bland
unclebilly's Avatar
intermittant heat
Hi guys,
my 87 944 seems to put out intermitant heat. When I stop at a trafic light, and the engine idles, it starts blowing cold air. If I rev the engine, warm air keeps coming out of the heater. I alsmost froze my dad to death the other day when I left him in the car for a few inutes when I went into a store. My guess is that there is probably air in the cooling system so I'm seeing a large bubble pooling in the heater core if I leave it idle... - thoughts?
Additionally, there are 2 9 pin? connectors didconnected under my steering column - the cruise doesn't work and the heater blower only blows on defrost or full tilt boogie. The heater problem doesn't seem to be the relay and admitedly, I haven't pulled the heater cover off yet to check connections etc on the blower. Could there 9 pin? connectors under the dash be related to either of these problems?
Old 01-05-2004, 09:54 PM
SoCal Driver's Avatar
The flaps in the air box are vacuum operated. You may have a loose or cracked vacuum line coming into the car.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 01-05-2004, 10:02 PM
Sabyre's Avatar
Also check your themostat, coolant level, and maybe bleed the system. There is a bleeder valve screw on top of the motor.
"We are the music makers and we are the dreamers of the dreams" -Willy Wonka
Old 01-05-2004, 10:32 PM
Send a message via AIM to TheCooler
My car is the oposite. Its blow hot all the time. Its really annoying. How do i fix that one?
-2002.5 GTI VR6 24V 6SPD
-Kalahari Beige 89 Porsche 944S2
-87 VW GTI 1.8 16v
-2007 Ford PIMP(free)star ...company car....
-1999.5 Jetta VR6
Old 01-05-2004, 11:16 PM
Fix the plastic lever/piviot just above the gas pedal.
Old 01-06-2004, 07:52 AM
Parrothead member
VINMAN's Avatar
check the vacum line and the linkage on the heater conrol valve
Vinny
Old 01-06-2004, 07:55 AM
bryanthompson's Avatar
Send a message via ICQ to bryanthompson
you guys rock. I just had this question last night, but was going to wait until my name fell off the front page of questions asked until I asked it. Being a newbie still, I don't ike seeing a dozen of my own questions.
1983 944 - Sable Brown Metallic / Saratoga / LSD : IceShark Light Kit
Old 01-06-2004, 01:23 PM
