Banned
Send a message via ICQ to Craig944
Post 944 S2
What are the specs for a S2?
Horsepower
0-60
1/4 Mile
Torque
Old 08-20-2001, 04:12 PM
Bob's944's Avatar
Send a message via AIM to Bob's944
208 hp at 5800 rpm
207 ft/lbs at 4100 rpm
0-60 6.5 sec
top end 142 mph
US VERS 10.9:1 compression ratio
Old 08-20-2001, 06:00 PM
Location: Saint Louis, Missouri, United States of America, Earth
Send a message via AIM to Allldi
According to my owner's manual (US car):
Power: 208 hp at 5800 rpm
0-60: 6.9 s
1/4 mile: 15.1 s
Torque: 207 ft-lb at 4100 rpm
Top speed: 149 mph
Ryan
1991 944S2 coupe
Old 08-20-2001, 10:48 PM
Z-man's Avatar
Post
How many S2 owners are this board?
S2 roll call:
I've got a Guards Red 1989 coupe.
and from the post just above,
Alldi (Ryan) has a 1991 coupe.
Who else?
-Z.
My toy: http://www.pelicanparts.com/gallery/Z-man
Old 08-21-2001, 06:52 AM
Post
I have a 90 black coupe.
Eugene
Old 08-21-2001, 07:53 AM
Post
90 Black S2 coupe,K&N cone filter up front, Autothority Chip & short shift,B&B cat back, Web Cams. Just finished putting it back together, goes fast enough for me now!!
Old 08-21-2001, 08:53 AM
Post
How many S2 sold in US or worldwide? I think Porsche didn't make many of them.
Old 08-21-2001, 08:56 AM
Non Compos Mentis
Post
1989. White.
Old 08-21-2001, 08:57 AM
Post
I have a 91 s2 cab.
George
Old 08-21-2001, 09:03 AM
Post
91 944S2 Cab. Port, Polished, shaved head,Elgin cams,Huntley adjustable cam gear,
Huntley Stage 2 MAF system,adjustable fuel pressure regulator,flow matched injectors, Nology Hot Wires, Nology Power core amp, Nology Pro Fire coil,Beru Silver Stone plugs,Autothority Chip and custom 2.5" exhaust with High flow cat.
17x8 wheels front with 225/40/17
17x10 wheels rear with 275/40/17
Dyno'd at 226Hp to the ground
0-60 in 5.7sec
1/4 14 flat at 102mph
Old 08-21-2001, 09:50 AM
Z-man's Avatar
Post
And they say that S2's can't be modded! Nice job, ehpower! I have a question: the authority chip: how much, where can I buy one, and what can I expect from it?
Thanks,
-Z.
Good list so far...
Old 08-21-2001, 10:43 AM
RPM'S S2's Avatar
Post
Arctic White 89 944 S2
No modifications - at 120k miles she runs like a horse, a big torquey horse!
Old 08-21-2001, 11:48 AM
Post
1989 S2
Baltic Blue/linen, 110,000 miles
17 x 7.5 and 17 x 9 "993"-style wheels
225 and 245 40-series Potenza S-03s
Stock otherwise; awaiting Koni availability so I can put in the "autocross" suspension--she rolls like a Citroen 2CV now!
Doug
Old 08-21-2001, 02:10 PM
Blackfoot's Avatar
Post
eh, that sounds like you have put a lot of work & $$$ into your car. I'm guessing about $4-$5k in performance mods, unless you did some of it yourself, in which you saved on labor.
for me, i have those same performance numbers (259 hp fly, 300 ft lbs tq) due to the weltmeister chips & wastegate shim. and it cost me a total of $399. to me, that's the beauty of forced induction.
[This message has been edited by Blackfoot (edited 08-21-2001).]
Old 08-21-2001, 02:34 PM
Post
The chip was $400. It was one of the first thing I purchased for my S2. When I first put it in I did not notice a difference. I think it was the fact that expected more. After about six months I took the chip out to smog my car. At that point I discovered the chip did a whole lot. I notice the difference without the chip. My car felt very slugish without the chip. It also raised my redline by 500RPMs. Currently the chip is installed to help out with timing and the raised redline. The Huntley Racing MAF kit does the rest. One thing to think about is the cost. For the money I spent on my engine I could of purchased a 86 951.
Old 08-21-2001, 02:45 PM
Post
I spent about 6K on parts. The car is very fast and fun to drive but it is still not fast enough. I am thinking about either a super charger or maybe a V8 conversion. Have not decided yet.
Old 08-21-2001, 02:49 PM
Post
'90 S2 Cab, guards red, 97K miles
problems summary (last 6 months):
wiper motor
left from suspension noise
a/c refrigerant leak
low hum from engine under load (could be belt)
this site has been great in gathering info and references.
best concourse S2 I've seen is a guy in western PA, professional detailer whose name is "Dan", has an S2 same config as mine w/ 27k miles - unbelieveably clean
Old 08-24-2001, 12:54 PM
Post
1991 944 S2 Cabriolet
White with Blue top and blue leather.
81K miles
3rd owner.
new top, new mounts, new front wheel bearings, ALL new belts, rollers, seals and tensioners, water pump, thermostat and hoses.
Clutch was done about 20K ago. All that remains is the Cam chain tensioner.
Regards,
Max
Max
91 944S2 Cabriolet
89 911 Carrera (fomerly)
Old 08-24-2001, 01:06 PM
marko's Avatar
Post
1990 S2 Cabrio, Alpine White, 145,000 miles and runs great.
Old 09-01-2001, 03:21 PM
Post
Hey, fellow S2'ers
Any of you guys have cold-start issues? Mine takes about four tries before it catches...embarrassing, more than anything else. Runs perfect, once it's running. Could it have anything to do with DME relay? Temp sensor? Brain was replaced about 40K ago (the car's, not mine!). Thanks fer yur help!!
Old 09-01-2001, 07:59 PM
