paitken76's Avatar
I'm replacing the brake pads again, BUT do I need to do the rotors?
A couple years ago, heck maybe it was more like 4, I took my car into my shop as usual for a brake service. Freaked out over the price I had decided that I would do them myself like most everything else from that point on. (Of course most of my tech advice cam from this Pelican BBS and you friendly follks) To make a long story short, I'm in need of changing the pads again but am wondering if I need to do the rotors as well. Back then when I was pricing out brakes services everyone included new rotors in their prices, and I thought "Why? Mine look just fine" So do any of you know: 1. How long do rotors typically last? 2. How do you know when you need new rotors? Warning signs, things to look for. 3. Should I replace them as well when performing a brake service? And finally, 4. Advantages of using cross drilled over the OEM standard 944 NA rotors?
As always, Thank you all kindly for the advice!
Nile Green 1988 Porsche 944 NA
FR Wilk's Power Prom 2
Old 01-14-2004, 04:24 PM
SoCal Driver's Avatar
If you just have normal street travel and wear; NO.
If the brakes start pulsing bad then yes.
Had a set that looked like ripples on a pond after a big rock. Just kept replacing the pads. Took a while for the pads to seat but beat the price of rotors. Only replace them cause the part car I bought had better ones on it.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 01-14-2004, 04:50 PM
Wolf1's Avatar
Re: I'm replacing the brake pads again, BUT do I need to do the rotors?
1. rotor life is not a "fixed" time or mileage. It depends on your driving habits, type of pads used, etc..
2. Typical warning signs are: grinding noise, pulsating when applying brakes, etc...
3. If the rotors are still within specifications, resurfacing them is fine.
4. Cross drilled rotors cool a little better and allow the hot gases that are formed between the pads and rotors to escape, this helps to reduce brake fade. However, it also helps to reduce the life expectancy of your brake pads. There is always a trade-off..
75 914 - Undecided.
80 931 - Gone, but not forgotten.
72 914 - old toy- sold.
And a whole bunch of German scrap metal shaped like 924's.
Old enough to know better, and stupid enough to do it anyway!
Old 01-14-2004, 04:56 PM
The standard brakes are more than adequate to do nearly anything you may ask of them. If the rotor thickness is still within tolerance, they can be resurfaced and save you a bunch of money. Please do not use an air compressor to "clean the dust" off your system while repairing, the dust is nasty to the lungs. Use the spray brake cleaner and CLEAN rags.
Bob S. former owner of a 1984 silver 944
Old 01-14-2004, 05:36 PM
MrPants's Avatar
if i were to upgrade the type of rotors id go with slotted. ive seen pictures of cross drilled rotors that have cracked because of the cross drilling. they also have less usable rotor surface which is, in principle, worse.
if you want to stop faster (and as long as you are replacing pads) investing in better pads would be the most cost effective route i think.
84 944 Non Alcoholic
Old 01-14-2004, 10:39 PM
adrian jaye's Avatar
in words of one syllabul.
"no"
but down to cost, there is no harm in doing so.
I would say the OEM parts are probably better (depending on your application) than non OEM.
make sure the pads have the anti-squeel shims built in (which the OEM ones do)
otherwsie go OEM for both
The fear of God is the begining of wisdom <><
NotJustPorsche
Subscribe: notjustporsche-subscribe@yahoogroups.com
Old 01-15-2004, 02:43 AM
Writer/Teacher
CJFusco's Avatar
Send a message via AIM to CJFusco
"4. Advantages of using cross drilled over the OEM standard 944 NA rotors?"
I have noticed a HUGE improvement in stopping power since installing cross-drilled rotors... of course, that may have to do with the fact that the old rotors were original items and very, very worn.
Sort of like how when you replace your original, 20 year-old plug wires and notice a huge improvement, it's probably due more to just having new wires in there than actually having "performance wires"
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944.
Old 01-15-2004, 06:25 AM
thats mind point CJ
had you replaced with new OEM parts
I think you'd still have noticed the same improovement
NotJustPorsche
Old 01-15-2004, 07:45 AM
