ruechaos's Avatar
Unhappy Got the emissions info today: Tell me what you think
It failed big time....
HC - 5.6025 State requires 2.0
CO - 156.5490 State requires 30.0
NOx - 0.3193 State requires 3.0 (*PASSED*)
So what can I do guys? The state requires that I put in at least 200$ into fixing the problem. What do you guys sugest?
Thanks!
-Tony
Old 09-17-2001, 02:45 PM
ae1969's Avatar
Send a message via ICQ to ae1969
Post
..uhmm... put $200 into it.... or sell it?
not much choice...
WHere did the $200 figure come from...and what does that entail.
Old 09-17-2001, 02:54 PM
Post
good plugs, new wires, a cap and rotor along with a fuel filter or O2 sensor and some injector cleaner will get you close to the magic $200.00 figure.
Old 09-17-2001, 03:11 PM
mideastmafia's Avatar
Send a message via AIM to mideastmafia
Post
put some "pass emissions guaranteed" stuff in your gas tank. my car runs REALLY rich and it passed with FLYING colors.
SHAUN
Old 09-17-2001, 03:14 PM
Post
and also, make sure to drive your car around a bit before going to emissions. the engine has to be warn for the 02 sensor to work right.
SHAUN
Old 09-17-2001, 03:15 PM
Post
Bzzz, you loose.
No way a can of "pass whatever" is going to fix an emmission profile this bad.
Old 09-17-2001, 03:33 PM
Bay Area Patriot
TheStig's Avatar
Post
open up your DME and turn it 3 teeth counterclockwise...try that first and then go smog it again.
Porsche. Es gibt keinen Ersatz.
Old 09-17-2001, 03:39 PM
ruechaos's Avatar
Post
After reading the info packet that they gave me, after it fails the second time, so long as I show that I have put at least 200$ into fixing the problem, I can get a waiver, which I can then use to go get plates. All I have to do in order to get it retested is maybe change the oil or replace some spark plugs.
I'll get this thing right, probably end up costing near 700$ though....
Now I see why these things are so expensive to maintain.... =)
Thanks guys!
-Tony
Old 09-17-2001, 03:49 PM
Post
euro, the factory position is allready all the way over. you can only move clockwise. going counter wont work. you need to move it 4 points clockwise for it to be set at -3% lean.
SHAUN
Old 09-17-2001, 04:05 PM
Cool
Tony, in your last post about you emmission problems I replied with 2 links. I guess you didn't read them but those numbers are the same as the ones from my car the first time I tested the car and failed.
http://www.pelicanparts.com/ultimate/Forum5/HTML/004383.html
http://www.pelicanparts.com/ultimate/Forum5/HTML/004427.html
The car is running overly rich change the O2 sensor ($45) and spark plugs, that will make the biggest difference. Taking the car for a long run not only gets the O2 sensor hot but more importantly gets the CAT hot so if it's not burnt out it will have a better chance of neutralizing the HC and CO components of the exhaust. When the mixture is rich the exhaust gases are not as hot as that of a lean mixture condition.
Been there done that !!!
Mark
'86 944NA
[This message has been edited by mlue (edited 09-17-2001).]
Old 09-17-2001, 05:34 PM
porsche1984944's Avatar
Post
could just register you car in a state that doesnt have emmission testing like me thats why I dont have a cat.
Old 09-17-2001, 05:41 PM
