Driver
Sick car
1st post, heve lurked a bit & learned much.
Hello all,
I'll give the story as complete as I can:
I took my 1987 944na into the shop about 5 days ago and had the oil pressure sender and the fuel filter replaced (all parts are OEM).
When I got the car it was running fine. In fact I noticed some smoothing out at higher RPMs that I attributed to the new fuel filter. Also the oil pressure gauge no longer jumped around, indicating the sender was working properly.
I drove the car for a few days after that and had it up on a lift to have a tech check something out. The tech did nothing to the car, it was just a visual inspection. After that I drove the car until last night, when it was parked until about 10:00 am today. It was about 3 degrees last night, but it has been that way for a few nights now.
Upon turning the key, the car started, idled very low and died when I took my foot off of the gas. After I get the car running for a few minutes (by keeping my foot on the gas) it will stay running, but at a very low idle seemingly very near stalling.
Any help will be greatly appreciated.
Thanks,
'87 944
Old 02-01-2004, 03:32 PM
Writer/Teacher
CJFusco's Avatar
Send a message via AIM to CJFusco
well, try revving it a few times until the idle raises... it could be that the extreme cold is messing with the fuel system. when it was -20 a few weeks ago here in CT, my car would start rough and stumble, and then run fine after I gave it some gas and let it warm up
now that the temps are up near 35F, the car has no trouble
welcome to the board
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944.
Old 02-01-2004, 03:35 PM
TNT25169's Avatar
Send a message via AIM to TNT25169
Could be the fuel pump....
-1988 Black 944 w/ yellow koni's, coilovers with 250lb springs, adjustable camber plates, strut tower brace, weltmeister front and rear sway bars, 968 caster blocks and 5 pt harnesses
www.apartabove.com
Old 02-01-2004, 06:30 PM
Writer/Teacher
CJFusco's Avatar
yeah, it could be... but the extreme cold temp keeps jumping out at me
Old 02-02-2004, 07:40 AM
SoCal Driver's Avatar
Yeah. Cold! Got down to the low 50's here early this morning. Had to turn on the wall heater.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 02-02-2004, 08:25 AM
Driver
update
Took it to work this morning. Same problem on start up, got it idling (again seemingly near stall).
When I worked the accelerator (gently) to rev the engine I got some sputtering between 2K & 3K RPM.
Halfway through a right hand turn I lost power, which then came back with a surge, after that no problems. Started it about 4 hours later, same thing.
I took it back to the guy that installed the fuel filter to insure there are no leaks. It seems to me that the problem is one of pressure not supply, which is why I am thinking/hoping it isn't the pump.
Waiting for the mechanics call, I appreciate the input.
GHEN
'87 944
Old 02-02-2004, 08:31 AM
Writer/Teacher
CJFusco's Avatar
haha, must be nice, SoCal. It is near 40 here in CT today, which feels like paradise. Time to wash the 944 (it needs it!).
it sounds like you have some kind of fuel delivery problem, Ghen. Maybe run some fuel injector cleaner? It might be something more serious, but one should always try the easy/cheap stuff first!
Old 02-02-2004, 10:16 AM
gtroth's Avatar
Mine did that stuff at 2.7°F a week or two ago. I dumped a bottle of Gunk's equivalent to DryGas in (they ran out of DryGas...) and voila, no more troubles. I've driven it a few times at as low as ~5°F without the stumbling, not 2.7°F yet, however.
Might give that a try.
1995 993C4 guards red
1988 944S alpine white
Old 02-03-2004, 04:02 PM
