justin's Avatar
What do you guys think about this....
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=38656&item=2457851985
Think it will make a difference? I know they work on v8's, but do you think it would slow the alternator down to much to charge good?
Texas hosts the 928 Owner’s Club OCIC in 2009
www.928ocicdfw09.com
1980 928 5 speed and a few mods..........
928 OC member
PCA member
Old 02-10-2004, 01:52 AM
Certified Rennwerker
924Sman's Avatar
Send a message via MSN to 924Sman
Only thing different is the material and weight. Diameters are the same as stock so I can't see how it would effect the Alt. Pulleys still travel-rotate the same so it isn't like you put a lower gear in. Less weight will let it spin easier but it can only spin as fast as the rpm's go. Sman
PCA " I've been everywhere, done everything......just can't remember any of it!"
Old 02-10-2004, 01:59 AM
scheistermeiste's Avatar
Send a message via AIM to scheistermeiste Send a message via Yahoo to scheistermeiste
i heard power pullies on other cars vibrate the hell out of the car, is this true?
Special Edition 924S 1988 <- SOLD!
Asking if you should replace that timing belt is like asking if you should re-use a condom that may have in hole in it with a hooker.
Old 02-10-2004, 09:44 AM
Unless you're racing at extended 7000+ RPMs I wouldn't bother with this.
Old 02-10-2004, 10:26 AM
TCMdocs944's Avatar
I like that someone is actually making an option! That price though....whew.
83 944 white w/Boxster wheels
Planned mods- custom leather interior, 968 antenna, soundsystem, 968 style rockers, clear sidemarkers
Old 02-10-2004, 02:27 PM
Composite Shop Owner, DJ
MixMasterK's Avatar
Send a message via MSN to MixMasterK Send a message via Yahoo to MixMasterK
The alt pulley is smaller if you look at the comparison pic. Looks like the crank pulley may be slightly smaller as well. They don't have an old power steering pulley on the ad to compare to their new one though.
'86 944, 5 Speed (Daily Driver)
Old 02-10-2004, 07:50 PM
MixMasterK's Avatar
Noticed these a few weeks ago as well.
Old 02-10-2004, 07:51 PM
7hp. A guy into racing who spent considerable time and money on dynosessions trying to come up with 2 or 3 hp found 7 by running synthetic vs conventional motor oil. He also got 9 running a test pipe instead of a cat. That's expensive for 7hp in my mind. Where are the 7hp, peak, 2300 rpm? The horses probably cannot be felt, but are probably real, and probably there is an increase throughout the rpm range. If you are doing everything you can to improve performance, this will help, and aftermarket bolt-ons that add hp are hard to come by. But maybe the $ would be better spent toward a nice set of Fuchs, or some turbo brakes, maybe new wires clean injectors and new filters, or even retensioning your belts.
'86na, 5-spd, turbo front brakes, bad paint, poor turbo nose bolt-on, early sunroof switch set-up that doesn't work.
Malo periculosam, libertatem quam quietam servitutem.
Old 02-10-2004, 08:04 PM
justin's Avatar
Im with Taz on this one, that price is too damn steep for 7hp.
928 OC member
PCA member
Old 02-12-2004, 11:31 PM
Z-man's Avatar
Taz: very good point. Too often people spend $$ on go-fast goodies only to be disappointed, and must spend more and more for more power. Thus, the slide down the slippery slope begins!
-Z-man.
2010 Cayman S - 12-2020 -
2014 MINI Cooper S Coupe - 05-17 - 05-21
1989 944S2 - 06-01 - 01-14
Carpe Viam.
Old 02-13-2004, 06:39 AM
