-   -   Replacing check valve (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/14952-replacing-check-valve.html)
Allldi 10-13-2001 05:08 PM
Has anyone replaced the check valve in the fuel system? I'm having a hot start problem and I'm thinking my check valve might be the culprit. I ordered a new one from Pelican but I'm not sure where it goes. I looked around by the fuel pump and the fuel filter but I didn't really see it. Am I just missing it, or is it in a totally different place? If I correctly understand the check valve's function, then I assume that the valve should be somewhere in the output line after the fuel filter. Also, do I really need to relieve the fuel pressure before I replace it? If so, do I just pull the pump fuse and run the engine until it quits, or is there a better way to do it? Any help would be appreciated.
Ryan
1991 944S2 coupe
dk944s2 10-13-2001 05:45 PM
Hi Ryan,
Just had my check valve replaced, but as my mechanic did it, I'm a little short on details. He said the valve screws into the fuel pump itself, which is located in a recess on the underside of the tank. The plastic cover over the tank must be removed for access.
Yep, pulling the fuel-pump relay while the engine is running is a good way to de-pressurize the system. BTW, replacing that valve totally fixed the hot-start problem I was having. Good luck!
--Doug
drew1 10-14-2001 07:58 AM
replaced one. they are brass & screw into pump.
Allldi 10-14-2001 03:03 PM
Does the valve screw into the input side or the output side of the pump? If it's the output side, do I have to remove that big plastic cover that covers the tank with the strap around it or just the little cover that covers the rear of the pump? If I have to remove the big cover, how should I support the tank while I remove the strap in order to remove the cover?
Ryan
1991 944S2 coupe
gzhiyingzhao 10-16-2001 10:07 AM
Hi Doug,
I have a hot start problem too. Since cold start is OK on my car, (even after it sits for a long time) I am wondering if check valve will fix my problem. Before you change the check valve, do you have trouble to start your car when it is cold?
Thanks,
George
91 S2 Cab
drew1 10-16-2001 01:27 PM
Alldi,
it is on outputside of pump & with banjo bolt, I think little cover is all you have to remove.
drew1 10-16-2001 01:28 PM
gz,
no hot start is a symtom of bad check valve.
